Question about Whirlpool LEW0050P Electric Dryer
This is a front loading whirlpool model lew0050pq2 dryer. we need to replace the door catch as the dryer will not power on. how do we take off the front panel?
  • cathryng Oct 06, 2009
    yes, I've seen the drawings, but don't quite understand how to get the front panel off to replace the door catch. do i have to come at it from the top?
    President:
  • 1,865 Answers
Go to the following website; there are 3 links under the "Browse subcomponents" heading. Those links will take you to the assembly drawings of your machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=lew0050pq2&=part+number
Posted on Oct 06, 2009
Whirlpool lew0050pq2 electric dryer
very good chance that is it
Apr 06, 2014 | Whirlpool Dryers
I know it takes 2 minutes to start, but my washer doesn't catch when you close the door, it takes about one hundred times for me to open and close the door until it actually catches and goes into...
I suspect a lid switch. Go here for your model and help
http://appliancehelponline.com/index.html
Please rate me thumbs up and testimonial, if this helps
Thanks
Leo Ponder
imufo2
Aug 16, 2011 | Whirlpool LTG6234D Front Load Stacked...
I have a whirlpool duet dryer, the previous owners did not leave a instruction manual with it. The problem is that the door will open while the clothes are drying. I have tried all different settings but...
The mostly likely problem your having with the door popping open isa weak or broken door catch,that is one of the easiest things to replace,just pop out out the old one and pop in the new one.I have included a link showing a image of the catch and several options of where to order it online. As far as manuals you could go to Whirlpool.com/owner center enter in your model# and download manuals
here is the link for the door catch
http://www.google.com/products/catalog?q=whirlpool+dryer+door+latch&rls=com.microsoft:en-us:IE-SearchBox&oe=&rlz=1I7ACAW_enUS360US360&um=1&hl=en&bav=on.2,or.r_gc.r_pw.&biw=1093&bih=538&wrapid=tlif131194571532910&ie=UTF-8&tbm=shop&cid=1042887075538779273&sa=X&ei=HLQyTq7CL8yctwfXwumcDQ&ved=0CGUQ8wIwAA#
Jul 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I need to replace a sensor kit on a whirlpool dryer model len2000pwo. should i go in from the back of the dryer or front/top!!! The part was in the dryer drum when i found it so im not sure the best...
Disconnect the power source to your dryer before you begin to open its cabinet. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Opening the cabinet for newer Whirlpool brand models starts at the control panel. Begin by removing the end caps found at either end of the console. Lift them from the back, and then pull them towards you. There will be two screws holding the console in place. Remove the screws, and then slide the console towards you and flip it up. You will find an additional three screws at the back of the cabinet top. Remove these and slide the cabinet top towards you and lift it off the unit.
Proceed by removing the kick-plate. There are two spring catches that need to be disengaged before you can remove the kick-plate. Each spring catch is found about four inches in from each side. Use a putty knife or some other thin and flat object to wedge in between the front panel and the kick-plate. Push down on the clips with the putty knife to disengage.
Open the dryer door and remove the screws that are holding the hinges to the door. Tilt the door up and pull on it gently to remove it. Continue the dismantling process by removing all the screws you find that are holding the front panel to the unit. There will be door switch screws, ground wire screws, and other screws holding the front panel to the bulkhead.
Reassembling the entire unit is basically the disassemble process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kick-plate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
Dec 01, 2010 | Dryers
My dryer(LEW0050PQ2) power button appears to operate and red button comes on when power button is pressed. But when the start button is pressed-there is a high pitched tone and the red light starts to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Whirlpool LEW0050P Electric Dryer
I'm trying to replace the door catch on the front panel of a Whirlpool Dryer model GEW9868KQ1. I've replace the piece on the door but can't figure out how to get the front panel off.
Hi, You shouldn't have to remove the front panel. Just squeeze the latch hard enough to remove it. I hope this helps. Please let me know if I can be of any more assistance.
Thanks
Vic
May 16, 2009 | Dryers
I looked for door switch kit and some descriptions say for stacking...i don't need that and have duet model 9200 in white. want both doors to open in opposite diections. do i need to buy kits?
ummm.. you can only reverse the door opening in oyour dryer, your washer CANNOT be switched it only opens to the left. the dryer can be switched and the "hine kit" if applicable, only contains a new peicw of trim to cover the exposed trim after revesing the door( the catches are on top and bottom no need to reverse them)
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWZ 412 - Door not opening..
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Apr 13, 2008 | Hotpoint WD52 Front Load Washer / Dryer
Whirlpool LEW0050P Electric Dryer Logo
111 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
