Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Colors seperated on screen
When i woke up this morning and turned tv on the picture was seperated into red,green,and blue colors
  • Anonymous Dec 25, 2007
    colors separated - words appear doubled/overlapped
  • Anonymous Dec 26, 2007
    Same thing this morning on 25 Dec 07. Owned for 3 years and 1 month. Only my red has shifted into a distorted pattern causing other colors to look strange . Refocus did not work. I will attempt to investigate more tomorrow. Already looking at an LCD replacement just in case repair is not cost effective.
  • 1,113 Answers
You have convergence issues
See this link
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html
and this one
Posted on Dec 29, 2007
Picture has red tint
I would unplug it from the wall for a while and see if that will help reset it. Also make sure there are no magnetic devices near the screen because this will change the screen color as well. Mine will mess up every once in a while so I just unplug it while I am off running errands, plug it back up when I come home and it seems to reset itself. Good luck
Jun 15, 2014 | Emerson EWF2004 20" TV
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Screen has a Green Haze to it........
1. CHECK FOR LEAKY Q6R1 (RED CRT PCB), Q6G1 (GREEN CRT PCB) AND/OR Q6B1 (BLUE CRT PCB). PART # 260P627020
Apr 20, 2007 | Mitsubishi VS-5043 50" Rear Projection...
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
