Question about Polaroid FLM-3734B 37 in. LCD HDTV
I have a polaroid hdtv model TLA-d1911c that wont get a local channel.I bought a new antenna and hooked it up but it still wont pick anything up.
    Scholar:
  • 102 Answers
You may be looking in the wrong place or have the wrong kind of antenna. With the digital conversion, TV channels shifted from the numbers they used before. In my area, the previous Channel 6 is now broadcasting in the UHF band.
It can be harder to adjust the antenna for a digital TV because it is either working well or totally off - no gradually decreasing "snow" as a clue.
It is possible your TV is not equipped to pick up digital TV. There are converters to translate digital TV to analog signals for older TV. They cost between $30 and $70 depending on features.
Posted on Oct 06, 2009
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I'm trying to hook up an indoor antenna to my polaroid flm-3232 do I need a digital converter box or does the tv have the necessary components?
You have an analog TV, meaning that the tuner in your TV is analog only. You must buy a digital converter to see broadcast Digital TV via your external antenna and it will be attached to the antenna input jack or other jack depending on how it comes out of the converter.
One bit of advice, there is no such thing as a "digital" antenna, they are all analog. Even a 50 year old, outside antenna aerial that you see out in the countryside will pick up the new Digital Broadcasts to be converted by a Digital Converter and displayed on a 50 year old TV.
Oct 21, 2012 | Polaroid FLM-3232 Television
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Tv wont pick up any freeview channels
You should still have to hook up and utilize an HD antenna to pick up your local HD stations
Dec 01, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Missing channel I used to get (using Broadcast)
You simply need a "Better" antenna system.
Feb 11, 2010 | Polaroid FLM-3232 Television
I have a Polaroid TLA-01911C. I switched from cable to air and did a scan, but no channels are found. I even hooked up an antenna with no channels found. Any suggestions?
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Jul 18, 2009 | Polaroid TLA-01911C TV
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
I'm trying to install an antenna on this model tv but can't seem to get a signal from the antenna to the tv. Is there a setting on the tv that I need to change so I can get vhs/uhf channels?
There should be a selection for setup or channels. It should give you the option for cable or antenna. Next, what type of antenna? Indoor or out door?
Mike
Apr 07, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
260 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
