Question about IBM 6400 Matrix Printer
I replaced the shuttle and need to do the phasing adjustment. Can you tell me how?
    New Friend:
  • 64 Answers
There is awritten number on shuttle assy .enter this number as phasing value .
i have 3/4 printer their value is 37 ,if there is no number on shuttle then use 37 and then checked it.
Posted on Feb 28, 2014
    Problem Solver:
  • 5 Answers
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing
value when powered off then back on.
1. Install the ribbon.
2. Load full width (136 column) paper.
3. Power on the printer and set top of form.
4. Press Stop to put the printer into NOT READY mode.
5. Press Scroll + Scroll to unlock the Enter key.
6. Press Scroll + Scroll + Return + Enter to enter the CE Tests menu. (Press all four keys at the same time.)
7. The display will show “SERVICE / PRINTER MECHANISM TESTS”, the first menu item. Press Enter to enter the
mechanism tests menu.
8. Press Scrollor Scrolluntil
“PRINTER MECHANISM TESTS / HAMMER PHASING” is on the display.
9. Press Enter. The printer begins printing all H’s, each line preceded by the phasing index number.
10. Press Return. The display will show
“SERVICE / PRINTER MECHANISM TESTS”.
11. Press Scroll or Scroll until “SERVICE / HAMMER PHASE VALUE” is on the display.
12. Press Enter. The top line of the display will show
“HAMMER PHASE VALUE” and the bottom line will show the current phasing index number.
13. Press Enter. The phasing index (followed by an asterisk) will move up to the top line of the display.
14. Press Scroll or Scroll to increase or decrease the phasing index, then press Enter to activate the value as it prints.
Continue to increase or decrease the phasing index until the pattern of H’s appears.
15. When the print pattern is acceptable, press Stop. Printing stops, and the printer automatically enters the current phase
index value into NVRAM. The display shows “NOT READY”.
16. Press Scroll + Scroll to lock the Enter key.
17. Close the printer cover. Press Start to put the printer into READY mode.
NOTE: If you changed the phasing value, power down the printer, remove the shuttle cover, and write the new phase value on
the aluminum shuttle casting.
Posted on Oct 14, 2009
1910 Singer Hand Crank Machine shuttle hitting
Ok... great. That helps. Here is a manual for the 128 (the more modern version of the 27/28), on PDF page 9 there is an adjustment instructions for the shuttle area. Your shuttle carrier will be slightly different (no button to help remove the shuttle) but the adjustments are the same. Don't be a afraid to "tweak" your carrier gently with a pair of pliers if needed. I found my carrier had been bent slightly a few tweaks, straightened it out and gave me better results. The parts are hard to find and expensive.
http://www.parts.singerco.com/IPinstManuals/127_128.pdf
Aug 04, 2012 | Sewing Machines
Printronix P5215 not printing full columns. I have changed phase settings but still leaving characters from the right margin. Please help
If you are missing columns of print (vertically), the ink is making the hammer frets stick. The shuttle probably needs to be removed and the frets cleaned. This is a common problem.
Apr 19, 2011 | Printronix Line Matrix P5215 Printer
PRINTER PHASING PROBLEM. we have a printronix p5005b. The configuration of the pinter is corrupted and it shows that the correct printer phase is 111 but as i configure it to 111 the letter is still...
Just Press all four Key UP + DOWN + PREV + NEXT while printer is offline and then change Shuttle Speed 450 to 500 and then press enter... then try to change phase....
Dec 06, 2010 | Printronix Line Matrix P5005B Printer
A have printronix p5005 printer but printout not clear
Remove the black cover over the shuttle and look for a phase number hand written in blue marker on the right side of shuttle. Press the up and down arrows at the same time to unlock the control panel. Press left arrow to go to diagnostics. Down arrow and right arrow until phasing. Set phasing number same as what was written on shuttle assy.If it is making noise then the shuttle is bad.
Sep 13, 2010 | Printronix Line Matrix P5005B Printer
Textos distorcionados
Sympton: Horizontal misalignment of characters (Dots or characters move left or right from dot row to dot row or line to line)
NOTE: to check the phasing value, power down the printer, remove
the shuttle cover, and read the phase value on the aluminum
shuttle casting in a black marker. Should start with PH... You will need this number below!
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing value when powered off then back on.
1. Raise the printer cover.
2. Install the ribbon.
3. Load full width (136 column) paper and set the top of form.
4. Power on the printer.
5. If the printer is on-line, press the ON LINE key to place the printer off-line. “OFFLINE / CONFIG. CONTROL.” displays.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/unlock key combination can be programmed by the user. If = + > does not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the test begins. The current phasing value is printed on the left of the printed pattern of all H’s. As the pattern prints, compare the H’s to the figure below. If the phasing needs adjustment, go to step 12. If the phasing is OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*) appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press ENTER to activate the value as it prints. Continue to increase or decrease the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). *ENTER SWITCH LOCKED” briefly displays.
18. Close the printer cover.
19. Press the ON LINE key to place the printer on-line.
the shuttle cover, and write the new phase value on the aluminum
shuttle casting.
Apr 26, 2010 | Printronix Line Matrix P5005B Printer
No audio
When you install an operating system, you need to install the chipset
drivers, the graph drivers, sound driver.
This motherboard is old and phase out. So there is not much support
for the board.
There is one download for this board from shuttle, I posted the page
below and you will see the download. If this does not have the sound driver,
the only other two things you can do is go to devise MGR and see who made the sound hardware and see if they have it, or you can right
click on it and pick update software driver, search internet.
If you can find it or it does not find one for you, there is nothing you can do. Sorry.
http://global.shuttle.com/download03.jsp?PI=597&PL=2
Feb 06, 2010 | Shuttle MV43VN Motherboard
Motherboard users manual for Shuttle MV43V
think this might help its a phased out product
Nov 29, 2009 | Shuttle MV43VN Motherboard
My printronix printer making shadow while printing
Hammer Phasing Adjustment:
Important: The printer must be printing the Phase pattern of “H’s” when the
OK, go to step 15.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
shuttle casting.
Jun 04, 2009 | Printronix Line Matrix P5005B Printer
Print is unreadable - dots for each letter are spread around not a uniform letter
please give us a call 0845 223199 we can resolve your problem ..
Mar 27, 2008 | IBM 6400 Matrix Printer
IBM 6400 Matrix Printer Logo
390 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
