Question about Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
I have a RS267LABP side by side Refrigerator. Yesterday, the temp in both the freezer side and the refrig. side started climbing. I unplugged the refrigerator , while unplugged, I took the opportunity pull it out and vacuum all the dust and dog fur from the grill and space under the refrigerator. After about 20 min I then plugged it back in and reset the temps. to the previous levels. After running for several hours, the freezer side seems to have returned to the normal sub-zero temperature that it was set to prior to the trouble. The refrigerator side has only cooled down to around 43F as indicated by the refrig. thermometer sitting on the shelf in side the refrig. Prior to the trouble the refrig. side had been set to 34F the actual temp on the thermometer on the shelf was reading 35F. The digital readout on the door says the refrigerator is now at 56F even though the actual temp is 43F. I would like my refrigerator to work as it did, what can I check or do to fix the problem?
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
Posted on Jun 17, 2009
  • 102 Answers
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
check the defrost circuit here is a helpful link to a service manual..in it t tells you how to initiate Forced Operation of defrost cycle.
http://www.servicematters.com/maytag_library/docs/SAM0059.pdf
Press Power Freeze and Fridge Temp. buttons for 8 seconds simultameously to get in the ready mode for a forced
operation.
The display panel will return to normal after 20 seconds in the ready mode.
At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
Another way to cancel this function is to simply plug out and in the power cord.
Posted on Sep 16, 2009
  • 67 Answers
SOURCE: The temperature reading on the outside door panel flucuates
Could be a fan problem, open the door and hold the door switch in, the fan should start and you should be able to feel air coming out the vents (air flow is not very strong as it comes out many vents so you will feel a cold breeze rather than a strong air flow if it is normal. Also check if you can see any ice nuild up in the back of the freezer as it may be a defrost problem and the air can't flow due to the ice build up, if this the case it will need to be looked at.
Posted on Apr 18, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator and freezer warming, usually 34, -4.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 11, 2010
I GOT A SAMSUNG RS267LABP SIDE BY SIDE FRIDGE AND FREEZER THE TEMPS SEEM TO BE GOING UP ON BOTH SIDES,WHAT COULD BE THE PROBLEM?IS THERE A SERVICE REPAIR IN MY AREA ,NORTH BRANFOR ,CT
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Samsung 26.0 Cu. Ft. Side-by-Side...
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
GE Profile Arctica Refrigerator Displays OFF PSS29NGNAWW
Sadly i would say the board is malfunctioning and needs replacement. There is nothing in the fridge/ freezer that if malfunctions can cause that.
Sep 21, 2009 | GE Profile PCF25PGW Side by Side...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Defrost Mode
YOU MIGHT HAVE A GAS LEAK ON THE UNIT.OR THE COMPONENTS IN THE FREEZER COMPARTMENT ARE NOT WORKING WELL.BEST YOU GET AT TECHNICIAN TO HAVE A LOOK.GOODLUCK.MOHAMED
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
42 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
