Question about Cameras
Problem with the firewire port on Canon XL2 camera, computer dose not recognize the camera, can not capture to computer, firewire cable dose not fix the port on the camera well, very loose, is there a fix.
  • james7153 Oct 06, 2009
    there are no usb port on canon xl2, only firewire port, can this port be replace and what is the cost.
    looking into a service center option, also thanking about try out a new firewire cable before i sent it to a service center. any suggest of a good firewire cable for the canon xl2
  • Cameras Master
  • 6,487 Answers
If that's the case it will be better if you can buy a firewire to USB converter cable to make that transfer work for you, but the easiest way to transfer file from a memory card of your camera to your computer is to use a memory card reader....
Posted on Oct 07, 2009
  • 4,281 Answers
Check on camera you find usb ports on it.
Then connect your camera to computer with USB cable then you can use it in computer.
Let me know if you need more assistance.
Thanks.
Posted on Oct 06, 2009
  • Yes it can be replaced at nearest camera service centre shop.It cost about 30 to 40$ .
    Thanks.
How to connect canon gl-2 camcorder to computer
Are you using the proper Firewire cable to connect? Also, the GL2 has had issue with the Firewire port going bad. Try a different cable and see if that helps. It can't be a USB-Firewire cable either.
Sep 07, 2014 | Canon GL2 Mini DV Digital Camcorder
Do i need a cord to transfer my canon ax h1 footage to my computer?
Yes you need a IEEE 1394 (FireWire/i.LINK) cable to connect your camera to your computer.
Your computer also should have a Firewire port to connect this to your computer.
Else if you have a video capture card then you can connect the video out cable and capture the video from the camera.
Jan 03, 2011 | Canon XH A1 Mini DV Digital Camcorder
I have a Canon 7.4V video camera and want to connect my camera to the computer. How do I do that?
Instructions:
  1. Connect an i.LINK (firewire) cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
  2. Connect the other end of the i.LINK cable to the computer. NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  3. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  4. Cue the camcorder tape to the beginning of the video footage.
  5. Turn on the computer. Your computer should recognize your camcorder and automatically install the needed driver.
  6. Start the video capture software on the computer.
  7. Begin playing the recorded video in the camcorder.
  8. Begin importing the video with the capture software. It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Hope this has helped you.
www.austintelstarservices.com
Sep 04, 2010 | Canon Video Cameras
Canon vixia hv 30 not recognized by computer
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
Nov 16, 2008 | Canon VIXIA HV30 DV Camcorder
How to make dvd ,vcd from mini dv without any firewir port
You need and AV capture card to do that if you dont have a firewire port.
Use the supplied AV cable that came with the camcorder, connect the audio (left/white, right/red and yellow/video) to the capture card AV inputs and start capturing. You can make the setting on the capture card, whether it should be captured in DVD or VCD format
Aug 17, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon XL2 capturing problems
This is not a sarcastic reply - it's genuine. If you're serious about making video, switch to a Mac. I use an XL1 or 2 every day, never have a connection issue. Regards, Nik
May 26, 2008 | Canon XL2 Mini DV Digital Camcorder
Unable to tansfer video to computer using DV cable..
Pinnacle software will recognize the camera installed through a firewire cable once the camera is turned on. Windows movies software doesn't recognize DV cameras. You may be able to get capture to work if you go to Microsoft.com and download the Windows Media 9.0 Development Kit. I believe DV input is a capture option.
There has to be a 3rd party program installed to get it to recognize it.
Good luck on that.
Sep 20, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR 850
I did try the windows movie maker soluction but it still is saying no camera
Jun 01, 2007 | Canon ZR850 Mini DV Digital Camcorder
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
