Question about Fargo DTC550 Thermal Card Printer
Pendant l'impression, message: head lift error
Pendant l'mpression, un bruit se fait entendre et le message erreur apparait: HEAD LIFT ERROR. apr├Ęs annulation, l'imprimante marque
NOT READY.
j'ai une imprimante FARGO DTC 550
  • 3 Answers
SOURCE: ribbon mis-cue?
When you have a ribbon mis-cue, first remove the ribbon. Go to the printer driver, printing preferences, calibrate, sensors. Click sesors then send... You should hear 2 beeps. Put you ribbon back in and try to print again.
If you still have the mis-cue it is a belt issue all DTC400's made 2006 and prior have had this belt issue. I don't recommend fixing this yourself, send it to a authorized Fargo repair center. This way it is under warranty.
Posted on Jan 14, 2009
  • 6 Answers
SOURCE: fargo DTC 550 driver for windows server 2008 64 bit
Actually, Fargo drivers will not work on any 64 bit system - 32 bit only.
Posted on Apr 16, 2009
  • 6 Answers
SOURCE: Error/ Head Lift Error
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
SOURCE: HEAD LIFT ERROR ON FARGO DTC500
where can i go to solve this problem of printheadlift?
Posted on Oct 23, 2010
mariolands
  • 2296 Answers
SOURCE: MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 18, 2011
Mon tapis roulant sportcraft tx390 ,a commencer a sentir le brule 3 jour apret que jais du ajuste mon tapis car il avais tendense a bouge sur la droite et frote donc jais fait un ajustement et cest...
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Apr 12, 2012 | Cars & Trucks
Je viens de recevoir mon imprimante MG 6150 et lors de la mise sous tension, le message suivant apparait: 6A81 printer error has occurred. Turn off power then back on again. If problem persists, see the...
Bonjour nduvignac
J' essayerais de d?sinstaller puis de r?installer le pilote . D?branche l' imprimante pour ces op?rations , relance ton pc apr?s installation et reconnecte l' imprimante . Si le probl?me persiste , il faut retourner chez le vendeur avec l' appareil et le ticket de caisse .
Cordialement ,
fanaudi .
Jun 30, 2011 | Canon MG6150 Printer
Je ne peux pas ouvrir mon email yahoo,
Tout d'abord, je tiens d'abord à m'excuser pour mon mauvais français, je suis en fait en utilisant un logiciel de traduction pour m'aider, et n'ont pas étudié le français pendant plus de deux ans.
N'étant pas en mesure d'accéder mail Yahoo pourrait être n'importe quel nombrede problèmes, un mot de passe oublié, une connexion internet défaillante,automatiquement vous déconnecter.
Je voudrais commencer par tenter de se reconnecter à Yahoo, le "signe dans"option vers le haut de la page est ce que vous voulez utiliser pour cela. Le reste se passe de commentaires.
Il pourrait également être connecté à internet afaulty de votre côté, la meilleurefaçon de résoudre ce serait de redémarrer votre ordinateur.
Si cela ne fonctionne toujours pas, fermez tous les programmes non-essentiels et tentera de vous connecter à nouveau.
Encore une fois, je tiens à m'excuser pour mon français, et j'espère que cela aide!
May 05, 2011 | Computers & Internet
J'ai par erreur désinstallé mon scanner
Commence par deleter Director Player . Va ensuite sur Device manager ( gestionnaire des p?riph?riques ) et delete ( pas seulement d?sinstaller ) le pilote du scanner .
D?connecte le scanner . Va dans le Control pannel ( panneau de configuration \ programmes ) et delete le logiciel de ton scanner . Fais un restart .
Ne connecte pas encore le scanner . R?installe le logiciel pilote . Fais un restart . Attends que le systeme d' exploitation soit compl?tement stabilis? .Reconnecte le scanner et attends confirmation que le pilote est correctement install? . Cela devrait marcher ? pr?sent .
Si oui , r?installe Director Player et vois ce qui se passe .
Dec 13, 2010 | HP ScanJet 2300C Flatbed Scanner
Je possède un copieur Ricoh 1022 .il est en panne . il affiche SG 546 . Aussitôt j?affiche 107 en appuyant sur le bouton jaune pendant un moment .l?appareil se mit en marche pendant quelques...
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Error:0x07674dd6 on a HP 2575
hi,
First excuse my bad chool'english ;
I have the same problem. No body have a soluce for me but.... I have changing the power cable and that resolve the problem ! Then i loocking beter my cable and one of the three was broked. I repare them and now the photosmart works good with this cable to !
The error 0x07674dd6 => Power cable troubleshot. !
Have a goed day !
En Français.... J'ai eu le même problème. L'aide Hp en ligne ne connais pas ce message d'erreur et me disais de faire réparer l'imprimante. En démontant celle ci, je me suis aperçu que le cable d'alimentation était endommagé (un des trois fils était sectionné). J'ai reconnecté le cable coupé (une simple torsade). Et hop, le message d'erreur avait disparu. Tout fonctionne de nouveau tres bien. En fait, c'est le fil d'alimentation moteur qui est indépendant de l'alimentation générale de la machine.
donc erreu 076074dd6 => Vérifiez votre cable d'alimentation ! (le barracouda étant le système d'etrainement du support cartouche et appel papier)
Bonne journée
Nov 18, 2008 | Office Equipment & Supplies
PACKARD BELL avc VISTA Pilotes realtek a jour mais pad de sons
Avez-vous une carte audio pré-installée? ou est ce de celle la qu'il est question?
Nov 17, 2008 | Microsoft Windows Vista Ultimate Edition
Mon appareil canon ne marche plus!
Salut
Desole, mais mon francais est tres mal... Votre objectif a été endommagé dans la baisse et doit être réparé ou remplacé.
J'espere que ceci aide.
Thomas
Sep 19, 2008 | Canon PowerShot A550 Digital Camera
Tv panasinic
francais je suppose.....lol
ecoute dis moi si ta télé fait au moins du bruit au démarrage style sifflement ou rien.
si rien ne se passe c'est probablement ton alimentation a découpage qui a laché.
soit tu ouvres et ragrde si un fusible interne aurait brulé ou alors direction le réparateur
bonne journée ;)
Mar 31, 2008 | Televison & Video
Fargo DTC550 Thermal Card Printer Logo
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
