Question about GE Ovens
Microwave doesn't heat - GE Ovens
  • 2 more comments
  • s_dumas Oct 06, 2009
    I have a ge spacemaker xl1800. it makes a slightly different noise now when it starts, but doesn't continue as it runs. I have a pretty good general knowlege on electronics and I usually fix my own appliances, but I've never worked on a microwave. I removed the outer cover, and discharched the capacitor. I was just looking for pointers on what and how to test it now.
    I have a ge spacemaker xl1800. it makes a slightly different noise now when it starts, but sound doesn't continue as it runs. The microwave doesn't heat food. I have a pretty good general knowlege on electronics and I usually fix my own appliances, but I've never worked on a microwave. I removed the outer cover, and discharched the capacitor. I was just looking for pointers on what and how to test now.
  • s_dumas Oct 07, 2009
    I discharched the capacitor and removed it. it seems to be physically leaking a little, and it doensn't really discharge when the connections are shorted so i'm ordering a new H V capacitor and diode. thanks for the info.
    Scott
    thanks dmftrucker. you were very helpful.
    President:
  • GE Master
  • 1,922 Answers
If it still turns,but no heat, your H.V. diode, H.V. capacitor, or magnetron tube are at fault,the first 2 items are rather inexpensive, but the magnetron tube can get pricy i.e. $75-$100+
Posted on Oct 07, 2009
  • daniel  hendrickson
    daniel hendrickson Oct 07, 2009
    scott was this the problem then? if its leaking that needs to be replaced anyway,there may be pcb's in that cap if its leaking,most new caps are dry or have a non leak paste.good luck again thanks dan
    Top Expert:
  • GE Master
  • 75,822 Answers
If a user sets up a microwave and turns it on, one would expect it to heat the food in it. If it doesn't, it has probably developed an electrical fault. But that's probably obvious. If the unit has a touch panel and the display is not functioning and the unit is totally dead, it might be a fuse (but it may not). Listen to the Mechanic on this one, friends. Even taking a unit apart to replace a fuse can be exceptionally dangerous. Very dangerous voltages delivered at high current make a microwave work. How much value do you put on your life? You been warned, ait?
If the display is lit, the fuse in the microwave is good and a blown fuse is not the cause. (A blown fuse kills everything including the display and clock. It will act as if it wasn't even plugged in.) If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven. If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system. The cited symptoms and possible causes are general and some slight variation may exist in a specific machine. But the bad news is the same. It's this: there isn't much a user can do to fix the problem without exposure to extreme hazards. There are dangers lurking inside the metal box we all use so frequently (to the point we just about take it for granted). And they can be fatal. Don't even think about trying to repair a microwave. Be smart and be safe. The life you save may be your own.
Posted on Oct 06, 2009
  • 10,515 Answers
when you try to reheat something does everything "sound" like it's working correctly? It's just not heating?
If yes,
This usually means that your magnetron is shorted. The magnetron is the part that actually produces the microwaves inside the oven. It's not safe to change this part by yourself if you never have worked on a microwave before because the magnetron can hold a charge of 3000 volts if not discharged properly.
unless let me know along with make and model of the machine.
Thanks.
What is causing my ge single wall oven with built-in microwave oven not heating, only the fan runs?
Is it the microwave or the oven that is not heating? If the microwave is not heating it is more tan likely the magnetron. If the oven is not heating it could be the element or the control board.
Sep 01, 2014 | GE JKP86 Electric Double Oven
Microwave tray does not turn therefore microwave does not heat. When it turns it heats properly.
Hola Carlos,
See below a tutorial that shows how to diagnose a microwave:
http://www.desmontalo.com/index.php/como-se-desmonta-un-microondas-lg/
May 11, 2012 | GE JKP85 Electric Double Oven
Microwave work but will not heat
If will does not heat or boil water, then your microwave is defective even if it appears to turn on.
If you do not hear the 'usual' humming noise that the microwave normally makes when heating, then the Magnetron is most probably defective: if the unit is out of warranty, it will not be worth replacing as it is quite expensive.
Hope it helps!
Dec 17, 2010 | Ovens
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
My microwave is working but not generating heat.
Hi well you didn't give the name of the microwave so i cant send you links but from my knowledge when that happens the heating coil burned out my microwave did that a few months ago and i had it replaced and it is regular for it to work its just not generating the heat.
Hope I Helped Please Rate Hight Cause It Helps me
Thanks.... Nick
Apr 26, 2010 | GE Monogram® ZMC1095BFBB /...
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
Goldstar ma-1012W microwave oven doesn't heat food
Sounds like a bad magnetron (the device that produces the microwaves) - if the microwave is over 6-8 years old, it's usually not worth fixing.
Mar 17, 2009 | Ovens
Sparking when microwaving
heatman101
gfgh
Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
