Question about Kenmore Washing Machines
I have a Kemore Washer Series 80, Model #110.29852992. The switch that the lid activates when it is down has broken off. I have had this swtich replaced twice before. I would like to do it myself, how do I get the top off, already cut my finger on the sheet metal in the back. I know it pivots but how do I get to that point?
  • jimbomxc04 Oct 09, 2009
    I was looking for more detailed model specific instructions. I had a difficult time removing the front clips, to the point of destroying them. I now have discovered that there are 2 clips of the same design holding the back corners. The putty knife method to release the front clips did not work. I had to resort to using a small pry bar the get the push and lift needed, thus destroying the clips. I now have 2 more cuts to my hand due the deforming the sheet metal when the front clips finally released.
    I would appreciate more detailed instruction.
    I need to replace the lid switch. The information you sent is more detailed and has photos but I need more detailed instructions on how to release the top of the washer in order to get at the switch which is mounted on the underside of the top of the washer. From what I can see there are 4 plastic clips at each corner that holds the top of the washer on. I have released the front ones with a lot of difficulty and have destroyed them in the process.
    I thought that getting on line help would steer me trough this. I am not satisfied with the information given and will be forced to call a repair man on Monday.
    President:
  • 2,976 Answers
First, UNPLUG THE MACHINE.
To open the top, take a fairly stiff putty knife and insert it into the crack between the top & front panels. Insert it about 2" from the sides. You will feel a distince piece in there. You want to push this piece in. It is a locking clip. As you push in on it, lift up on the top. Once you have one side popped loose, stick something like a screwdriver in the opening so it doesn't lock back down. Repeat the spring operation on the other side of the lid.
Posted on Oct 10, 2009
  • 986 Answers
Here is a website with instructions. Hope it helps.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
Posted on Oct 09, 2009
    President:
  • 803 Answers
First of all, unplug your washer. You will need to remove the consoleI have a Kemore Washer - 2.gif in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Oct 06, 2009
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
80 series model 23822100 will agitate but won't
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: There is no need to drain the washer to repair the lid switch. However, if you need to drain the washer to avoid having stagnant water in the tub, you can by-pass the lid switch. Use the steps provided to access the lid swtich. Unplug the switch and remove it from the washer. With the switch in your hand, cut the connector plug off leaving about two inches of wire. Cut the center conductor (green wire) off flush with the plug. Take the two black wires and crimp them together and insulate with some electrical tape, or use a wire lug. You now have made yourself a by-pass plug. Plug this back into the timer plug and you have now by-passed the lid switch.
NOTE: This is to only be used as a TEMPORARY means of operating the washer and not as a permanent fix. The lid switch is installed as a safety feature to stop the washer motion when the lid is opened. Without it, you will not be able to stop the washer unless you push the timer knob in. Make sure you replace the lid switch.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Kenmore 22422 Top Load Washer
Kemore 80 series, washing machine will not drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Jul 08, 2009 | Washing Machines
Kenmore washer series 80 will aitiate but not spin with load
Jul 07, 2009 | Kenmore 22422 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Washer won't drain
The symptoms you describe are typical of a lid switch problem. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike.
If the lid switch is broken, you can find a replacement at searspartsdirect.com. If the model number you have this listed under is correct, just type it in the search menu at the Sears website. Type the model number in as follows : "110.1586400", or "110.1586200" to complete your search. A COMPLETE model number from the washer nameplate (located around the wash tub opening under the lid) would be more helpful. You can find the switch under the "Top and Cabinet" heading as item number 11. The lid strike is listed under the same heading as item number 20. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
If the lid switch is functioning properly, you may have something binding in the drain pump. The lid switch is an easier option to attempt first as it does not require you to drain the tub in order to repair. If the switch is not the problem, please post back and let me know. The drain pump is easy to replace, but will require some effort in getting the tub drained in order to install a new one.
Both repairs are inexpensive and can be easily accomplished on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
Nov 11, 2008 | Kenmore 15864/15862 Top Load Washer
Kemore 80 Series stock # 26832
Yeah...check your lid switch. This is a very common description of a lid switch malfunction. In fact hitting the washer, or slamming the lid will make the problem progressively worse. The lid switch is located in the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first, then check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading for item number 11 (part number 3949238). If you do not wish to order online, take the part number provided and go to your nearest appliance parts retailer. This is a common part that most carry. The following link explains how to replace the switch:
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
Sep 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
