Question about Kenmore Refrigerators
Kenmore side by side fridge mod 106 52252100. the
Kenmore side by side fridge mod 106 52252100. the freezer is to cold ,-32C at lowest settig. unit appears to go through a defrost cycle dut the drain freezes up ( its not blocked ) except it freezes up upon the 1st defrost cycle it goes through after a physical shut down and defrost to a totally dry condition. Ice builds up @the bottom of the freezer like a glacier steming from the back of the freezer drain pan. you can see distinctive layers for what appears to be each defrost cycle. Also the food in the fridge compartment, chrisper is freezing.New electronic module $200.00 or a thermistor or drain pan heater?
help much appreciated
Daryl
pelletil@shaw.ca
  • 1462 Answers
SOURCE: Auto defrost not working correctly
the tray at the bottom which collects defrost water usually has its own heater or a section of the main heater runs close to it. check this part of the heater has continuity. an old trick as well which sometimes works is to wrap some copper wire round the heater and lead this to the drain hole. conductiuon of heat thro the copper helps keep the drain clear. this is a common problem across all makes
Posted on May 08, 2007
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Remove back of unit and check defrost heater has not become detached, otherwse the is only two possibilities, one a defrost fault and although you say the defrost tube is clear the only reason it does not flow is due to a restriction, what can happen is that the water backs up the drain pipe and then freezes before the water in the external tray can evaporate. Regards Advisor
Posted on Aug 24, 2007
  • 87 Answers
SOURCE: Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Posted on Sep 11, 2007
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
Kenmore freezer running but not fridge
is it a fairly new fridge with dual compressors, if it a single unit, you may have blocked the door that lets the cold air into the fridge side with food, or the door could be stuck shut.the door is located in the upper corner next to the freezer side of the fridge.
Aug 31, 2014 | Kenmore Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water condencing in refrigerator area.
your drain is clogged. defrost unit. remove back panel in freezer and unclog hole where water collects
Feb 10, 2010 | Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Problems with Kenmore freezer 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator?
Probably not toast just yet. Could be that the coil underneath the unit is just diry
Sep 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
259 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
