Question about Sony PlayStation 2 (PS2) Console
Disc read error i have tried adjusting the laser angle and it hasn't helped.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 273 Answers
Go here and go to the very end
www.powerfulguides.com/ps2
hope this helps :D
Posted on Oct 07, 2009
Clicking sound after spinning disk - error
The problem is the installation. A slight variation of the read head angle is all it takes to misalign the laser beam. If the angle is not precise, the light emission will not tract correctly, thus you get a read error. It is like phonograph needle sitting in a groove and making direct contact with the data sectors.
Dec 21, 2013 | Nintendo Wii Console
Can't play CDs in my car. The Unit gives me error code 4
The error 4 in most CD Player is an error that comes up when the laser pickup doesn't read the disc correctly. This happens most of the time because of a dirty lens in the laser pickup. If anyone smokes in the vehicle the smoke may be on the lens causing the error code. Try a wet type CD cleaning disc to see if it helps.
"Error 4" is a mechanical disc loading problem. The disc probably hasn't been seating in the #6 carrier properly, leading to some mechanical interference when it is selected. It would seem to be properly seated now, but next time you have it out you might check it on a perfectly smooth flat surface to be sure it is not warped slightly. Try another disc in that position, one you know to be trouble-free.
I burn a lot of discs for my clients and have never had a problem with the mid or high-grade discs from Taiyo Yuden, and others. Even lesser discs like Ritek perform fairly well. Some brands - usually the no-names - fail right out of the box. One of the problems seems to be that the cheapest discs are pretty thin and subject to mechanical problems like warping.
If you use "economy" discs particularly, be sure to put a label on them. Most of the cheap discs don't have much of a protective coat on top and scratching the top metal foil finish can lead to serious playback troubles as the disc is read by the laser from the bottom.. In addition to telling you what's ON the disc, the label helps protect that critical foil.
Hope helps.
Aug 20, 2011 | Car Audio & Video
Problem the wii console it is not reading any game disc
What error messages that appear on your screen?
If you see;
1 Disc read error or unable to reading disc, there is a problem with the laser lens, it can be happen if the lens is unclean, e.g. dusty, try to Cleaning the laser lens using disc cleaner. if you technical, try to make adjustment of the lens or replace the laser if necessary.
2 Error #001 - #002, you have a problem with wii system firmware, you need to updating wii firmware. If you have softmod/homebrew installed see here; http://e-arena.blogspot.com to get more help.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | Nintendo Wii Console
When disc is inserted it says 'unknown disc'
one particular disc? or all discs?
Unplug for 5 minutes and re-try.
Thanks
Jan 03, 2010 | Alba DVD55 DVD Player
CD PLAY WON'T READ THE DISC
i HAD THE SAME PROBLEM, I BOUGHT A SPECIAL DISC FROM TV/RADIO SHOP IT COST APPROX £5. I HAD TO RUN IT 5-6 TIMES TO GET IT PROPERLY CLEANED. ,I WAS GOING TO THROW OUT MY PLAYER AS I THOUGHT IT WAS GOING TO BE OF NO USE BUT IT IS NOW PLAYING AS NEW,HOPE THIS IS OF SOME HELP.
JACKIE
Sep 16, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony DVP-NS325 "Cannot read disc"
there is some problems with your optical lens that is why not spinning or reading data on disc. before change the lens adjust first the two trimmer for DVD and CD adjustment for laser beam.
Sep 09, 2009 | Sony DVP-NS325 Multi-disc DVD Player
Disc Read Error
the laser might just need re-aligning or the power adjusting so that it will read the discs again. cleaning the laser with a cotton bud and spit is as good as anything but only wet the tip a little bit enough to wipe the laser. The you would be better to adjust the 'pots' on the 360 laser because after a lot of use the laser unit loses power and starts to get disk read errors. we can fix this type of error and we will knock £5 off the price for all fixya users. www.fixmyconsole.co.uk
Jan 25, 2009 | Microsoft Xbox 360 Console
Lee playstaytion two
Hi Lee,
Your lasers on the way out.
it,s all to do with the power output of the laser head, and the angle for reading the 2 different disk types.
i,d suggest getting a new laser fitted. not too expensive usually with older consoles. Try E-Bay :)
Mike @ Compurepair.
Feb 18, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error for PS2 games
Hi Bunny,
Ur PS2 optical getting weaker and it needs service.Contact any expert for its service,And dont try to do it personally if u dont know about it.
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Optoma dv10
As a last resort only: There is a small screw on the laser unit that adjust the laser intensity. Small adjustments (keep a note of the original angle and other angles that you try) can help but be verycareful or you will render the laser as useless as **** on a boar.
Oct 26, 2007 | Optoma MovieTime DV10 Multimedia Projector
Sony PlayStation 2 (PS2) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
