Question about Canon SELPHY DS810 InkJet Photo Printer
I can't seem to get the cartridge holder to come to the middle so I can put in the new ink. If you can help me it sure would be appreciated.
    Scholar:
  • 56 Answers
Download the user manual and goto page 71. follow the steps.
http://gdlp01.c-wss.com/gds/0900005114/ds810_ppg_en.pdf
Posted on Oct 06, 2009
Hi I have just put in ink cartridges and the reg light check print cartridges keeps flashing is there anyone there to help me
Hello and Welcome to FixYa!
Sir/Ma'am If the Check Print Cartridge message is shown and Red Light Flashing then it means that Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. For it Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press push mark until ink cartridge click into the place.
If you are sure then you have installed ink cartridge properly then try following to stop the flashing of red Light.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
Now Turn On the printer, Mostly this issue is resolved by this,
But if still you get the message and red light still flash then surely its an issue of Ink Cartridge, your ink Cartridge is defective, You need to change the ink cartridge, Your problem will be solved.
I hope this solution helps you.Don't hesitate to let me know if you still have some confusion in your mind.
Please Rate my solution as "Maximum Stars" and then give your Words of Appreciation as a Feedback.
Thank you Sir/Ma'am for taking my service and fir using FixYa
Concerned: Muhammad Uzair Team : FixYa
Nov 05, 2011 | HP DeskJet 920c InkJet Printer
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
Installing a new color cartridge
Hi mariek2006,
Cannon printers usally the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridge will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your ink cartridge are reset with new ink.
Good Luck
and don't forget to leave a rating based on my solution.
P.S.
Don't forget to push the blue bar that is holding the top up in, and the top will slowly lower itself into place. Mark
Aug 31, 2009 | Canon Office Equipment & Supplies
I dont know how to take my ink cartridge out so i can put the refiil ink cartridge in.... i dont want to brake it... lol... help me
try to shut it off..and then force the carrier or the cartridge holder onto the middle by pulling it...
May 17, 2009 | HP DeskJet 6540 InkJet Printer
Where do i change the ink on my canon mp830 pixma?
Hello paulphipps1,
That printer the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridges will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your cartridges are reset with new ink.
Good Luck
Mark
Apr 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
How do i change the ink cartridge on my epson cx6400?
I am assuming that you already have a replacement ink cartridge.
  • Make sure the printer is on.
  • If the LCD screen says that your ink cartridge is empty than
you can simply press the Color button (the button looks sorta like a diamond with a line in the middle of it).
  • If you wanna change the ink cartridge but the printer does not say that it is empty then
press the setup button, then press the top left button until Replace ink is displayed. Finally, press the Color button.
  • Lift up the scanner section
  • Wait for ink cartridge holder to move to replacement position then open its cover.
  • Identify which cartridge you want to replace. Press in the tab to release the cartridge, then lift straight out.
  • Before unwrapping the new cartridge, shake it gently four times. Then remove from wrapper.
  • Lower new cartridge into holder, press down firmly until clicks.
  • Close cartridge cover
  • Carefully lower the scanner section and press it down until it clicks
These instructions were found in http://files.support.epson.com/pdf/cx64__/cx64__pg.pdf on pg 12.
Oct 12, 2008 | Epson Stylus CX6400 All-In-One InkJet...
How do I install a new cartridge holder?
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 30, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Click this link for a service manual free download for your multipass c2500 inkjet printer troubleshooting.
This will help you replace the holder.
If you cannot click just copy and paste the following link into your browser window.
http://www.nodevice.com/search.html
Apr 30, 2008 | Canon MultiPASS C2500 InkJet Printer
Canon SELPHY DS810 InkJet Photo Printer Logo
60 people viewed this question
old marine
old marine
