Samsung front load washer. Model# WF337AAR/XAA Error code E3
  • Jerry Kerns Oct 06, 2009
    You were very helpful!
    Thank You
  • Washing Mach... Master
  • 2,200 Answers
Hi
The E3 error on the Samsung is described as follows
"Machine control is attempting to drive the motor but is not seeing any tach response."
The primary causes of this are
1) A fault with the Hall Sensor - this is a sensor integral to the motor itself. When the Hall Sensor fails or becomes dislodged, the control
doesn't recognize that the motor is spinning and shuts down. You should inspect the wiring and connection to the motor is good. Also unplug the connectors and ensure that the wiring to the connectors is secure within the connector itself.
2) This error has also been known to show if the brushes in the motor are worn causing the motor to fail to operate properly or not at all. You will need to remove and inspect the brushes inside the motor for wear. Cost to replace is around $45 if you can do this yourself.
3) Verify the spin drum itself is not obstructed somehow and is moving freely when turned by hand.
For your information the Hall Sensor is a PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor itself.
Hope this helps. Please do rate my answer. Many Thanks.
Posted on Oct 06, 2009
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung vrt front load washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Errhr code ee
There is no error code ee
Could it be 3E or E3
if is 3E then it means "High current detected"
if its E3 then it means "Motor not running properly"
here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same.
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Jul 11, 2012 | Samsung WF337AA Front Load Washer
EnerGuide Rating?
Here is energy guide for your washer machine
Mar 04, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
359 people viewed this question
Top Washing Machines Experts
