Question about HP iPAQ HX4700 Pocket PC
I want to read a SDHC card on my iPaq hx4700 in addition to a 4G Flaskdisk which works fine. I previously flashed my ROM to Windows Mobile 6.1 (ROM revision = 2.61.20 PV) which works fine. I downloaded the SDHC Driver set. It instructs me to 1) Install SDHC.cab, 2) Overwrite /Windows sdbus.dll & sdmemory.dll 3) Install Certs.cab. I removed all storage cards, soft reset the PDA, then ran SDHC from my device and it responds with: Installation of SDHC.cab was unsuccessful.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I upgraded my hx4700 to wm6.5. The only way I can use SDHC is by using a CF-SD/SDHC adapter. I use the CF slot with a 16GB SDHC inside the adapter. AMAZON sells it for $11.78 http://www.amazon.com/adapter-support-Pocket-Professional-Digital/dp/B004F1OQDWI want to read a SDHC card on my iPaq hx4700 in - 41y-m3vg6jl._ss400_.jpg
Posted on Mar 07, 2012
Http://forum.xda-developers.com/showthread.php?t=499834&page=4 I haven't tried it, but he claims it works. The rest of the thread is an April Fools joke.
Posted on Jun 30, 2010
I just bought one 4BG SD card for my Hp Ipaq HX4700, but its dosen't show up. Please give me the suggetions, how can i use it ? Thanks in adnavce.
Use a CF-SD/SDHC adapter and use the CF slot. AMAZON sells it for under $12.00. I am using a 16GB SDHC right now.3_7_2012_7_17_35_pm.jpg
Aug 25, 2011 | HP iPAQ HX4700 Pocket PC
My new 4gb sd card does not register on storage display, and does not seem available to use
The official oprating systems of the HX4700, WM2003 and WM5, do not support SDHC card format. Since most 4Gb "SD" cards are in SDHC format (check the label on your card), the file format of your card is likely to be incompatible with the PDA. Get a 2Gb SD card, or go for a Compactflash card for 4Gb to 32Gb of storage space.
Jan 16, 2011 | HP iPAQ HX4700 Pocket PC
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Hp ipaq hx4700 hp invent is on but unit will not power up
I had the same problem which showed the exact screen you're describing and was able to sort it by downloading the ROM update from the HP site - they show it only available for US but works fine on UK machines as well. It takes a short while to install but has restored mine back to normal again. (only problem was incompatability with windows vista - works fine with XP)
Aug 23, 2008 | HP iPAQ HX4700 Pocket PC
Hx4700 Dead
Try reflashing the rom:
Aug 17, 2008 | HP iPAQ HX4700 Pocket PC
Do I have to hard reset after pc-break down
No!!!! ROM-update currently in ROM !!!!
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
Outlook 2002 Reinstallation
The default e-mail client on pocketPC 2003 is the "inbox" which is merly a utility for retreiving & sending e-mail. There is no "outlook 2002" on pocket PC's. The Outlook 2002 installation cd comes with most iPaqs and is intended for your pc, not your ipaq.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
HP iPAQ HX4700 Pocket PC Logo
1,370 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
