Question about Goodman Heating & Cooling
Goodman furnace has steady light no flashing and won't ignite changed ignighter , now makes noise but still won't fire up
  • Richard Johnson PE
    Richard Johnson PE May 11, 2010
    what noise? and what model? serial would be helpful as well.
  • frankrhoney May 11, 2010
    what is the model#
WebTeligent
  • 42 Answers
SOURCE: No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Posted on Nov 10, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Posted on Oct 21, 2008
SOURCE: goodman gmp075-3 led blinks 5 times
After fighting this thing for 2 weeks, I changed out the circuit board tonight and I have heat!!!! Barnett Brass is where I got it. $100
Posted on Nov 14, 2008
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Posted on Nov 15, 2008
heatman101
  • 43501 Answers
SOURCE: constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Heatman101
Posted on Dec 29, 2009
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
Furnace will not ignite.
I think you are talking about draft induction pressure switch operation. Make sure the metal orifice located on the draft induction blower is clear. To check, remove the rubber tubing end at the pressure switch and blow into the tubing. It should be easy to blow through it. If it is plugged, remove the tubing from the blower orfice and use a paperclip, inserting it into the orfice to clear the opening. After repairing, and all is hooked up, retry the furnace start up procedure. If the code comes up again, replace the pressure switch.
Dec 17, 2014 | Goodman Manufacturing...
My goodman furnace just like doesn't ignite because it light and then no fire coming up and then it stop. please help me
If the burners ignite and then turn off it looks likemthe flame sensor is the problem. On the opposite side of the igniter in the burners will be a metal rod, this rod needs to be cleaned with a steel wool pad. Once it's clean turn Furnace back on.
Dec 01, 2012 | Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
I have a goodman GMPN1 gas furnace It goes through the cycle but doesnt fire. I replaced the ignighter it is working but still wont fire.
have you checked the pressure switch and also to assure that the flu is clear? can you light the burner with a match and when you do how long does it run for? have you checked the clearance to the burner have you also assured that where the ignitor is pluged into is cleaned ive also noticed on another site there is a board issue with this model have you checked the board ? also have a look at this site as well its where I usually talk with other techs about issues they have with the goodman as well as other units http://www.contractortalk.com/f6/goodman-80-furnace-brand-new-wont-start-7006/ please message me back with the answers to the questions that I have asked and I await your reply Thanks again Rick
Jan 31, 2011 | Goodman Heating & Cooling
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble shooting light flashes three times.What part do you think is failing?
3 flashes is the combustion pressure switch . Mounted on the front mid high. Two silicone hoses run to it along with blue two wires. By now you have probaly got this fixed though.
Nov 16, 2009 | Coleman Propane Forced Air Heater...
Goodman furnace wont light, ignitor suspected (part#b1401015)- what does the ignitor ohm out at, and what is the input voltage upon ignition? I get steady 4.9V, then fan turns off-
Notice. I do not mind helping diagnose furnaces although I try to be cautious when giving advice on them. Please bare with me if I ask question. I don't want anyone burning their house down or hurting themselves and a furnace will do both.
You stated that you get a steady 4.9v then the fan turns off. Which fan are you speaking of? Also, the igniter should read 3.8 ohm's if it's good. The furnace should be sending 120 v to the igniter.
I'm not sure the igniter is the problem unit I receive a reply from question.
Oct 19, 2009 | Goodman Heating & Cooling
Tempstar dc90 furnace will not light
Possible solution would be to push the reset button if you haven't already. I have had to do it twice on my dc90 in the last week.
If you look at the glass where you can see the combustion chamber, the glass is oval, follow the long axis of the oval toward the 'top' of the ignition chamber (my unit is laying down, with the blower on the west end and the combustion chamber on the east, as I am facing south). On top of the chamber are two protected spade clips. In between them is the reset. Make sure that the unit is off, press the button, and fire it back up.
Feb 16, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
126 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
