Question about Casio EXILIM Card EX-S770 Digital Camera
When I take a photo during the day the photo comes all white with the flash and without it. But when I take a photo during the night the photo comes all clear and great.
    Brigadier General:
  • 11,967 Answers
Check your ISO setting. Try "auto ISO".
Posted on Oct 06, 2009
OptioM10, Horizontal white stripes appear on pics, during daylight. All ok w/ night pics w/flash. Any idea?
Hi there your lens sensor is getting down. Thats why in dark jone its come fine but in day light the sensor can not able to sence the huge light. So the white lines is come. I suggest you visit service center and replace the sensor. Thanks.
Mar 23, 2010 | Pentax Optio M10 Digital Camera
Tip
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
on Mar 04, 2014 | Nikon Coolpix S4000 Digital Camera
Green tint on flash photographs
without color correction software on your pc, you may get green tint from the flouresent flash, or use a "filter" over your lens.More expensive digital cams correct for this, back in the 35mm days, I had color correction filters I interchanged during shooting under other than daylight conditions,i.e., incadescent; flourescent;ect.
Jan 27, 2010 | Moultrie MFH-DGS-100 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Day time photos are white and other photos are not natural, either reddish or yellowish.
Please readjust the ISO.
In order to find a pattern please experiment: For example: Try Different SCN (If you're experiencing this problem with your night pictures try and use SCN night, the logo shows a moon and a star, with or without Flash.
Dec 18, 2009 | Kodak EasyShare C763 Digital Camera
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
Daytime photos are very white and has horizontal lines.
Hi!
If ever you haven't tried resetting the camera, please try it first. It's possible that you or somebody using the camera may have set something on the camera's setting to have this result ( this is based on my own experience :D ).
Anyway, here's how you reset your camera:
This will basically set the camera to default settings. If there is no hardware problem with the camera, this will correct the problem. However, if the problem persist after the reset , you may want to bring the camera in a service center for repair.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio Exilim EX-Z40 Digital Camera
Pink in the photos
maybe you use wrong white balance, test auto and manual white balance; if there is pink again then your camera have hard ware problem (CCD for exaple). I hope this helps...
Nov 01, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
Dgs 100
If the pink & white pics are a small percentage of your photos you should probably just live with it. I have 6 cameras in operation for 2 yrs & they have about 10% like this. Great pics otherwise. Probably caused by the angle of the sun or reflection of the flash off a nearby object.
Don
Jan 18, 2008 | Moultrie MFH-DGS-100 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
141 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
