Question about Homelite Consumer Products Backpack Blower/Vac, Carb
THE ENGINE RUNS FINE FOR 10 SECONDS THEN KIND OF DIES OUT BUT WILL THEN RUN FINE FOR 10 SECONDS AND THEN DIE OUT
  • 17 Answers
Try replacing the in-line fuel filter, the Air Filter and Spark Plugs. Also make sure that you are using the proper start up procedure. In many cases that means using the highest choke setting until the engine tries to start, then going to the next choke setting and so forth until you get to no choke. It is imperative that you let engine run for at least 5 minutes before use to warm up. This will ensure a longer life and consistent running.
Posted on Oct 06, 2009
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
Feb 04, 2016 | 1997 GMC Sierra
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
I have a 1993 Pontiac transport van and it will start up and run for 5 or 10 seconds and die
You may want to do a fuel pressure test to start. The pump could be defective. The fuel pressure should hold steadily and not decline with the pump off. If the fuel pressure falls, you either have a fuel leak, stuck injector, faulty fuel pressure regulator, or a bad fuel pump check valve. If the pressure holds at the correct spec, note the pressure as the engine runs and then dies. If the guage shows correct pressure, you can then move on ruling out the fuel system.
Apr 03, 2013 | 1993 Pontiac Trans Sport
Car starts and runs for about 10 seconds then dies but can start rightback up and do same thing run for 10 sec and then die
CHECK FUEL FILTER AND FUEL PRESSURE.......PUT SOME GAS IN THE TANK SOME TIMES GAUGE READS WRONG.......
Dec 20, 2010 | 2001 Nissan Maxima
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
92 gmc c2500 turbo diesel. starts then dies after a few seconds.
Sounds like the Pump Mounted Injection Module.. Starts, dies, Starts dies... Not a fun fix.. but atleast it's just under the intake..
Mar 30, 2009 | 1994 GMC Sierra
My car wont stay running
Does the engine die as soon as you release the key, or does it run for a couple of seconds after you release the key and then die? If it dies as soon as you release the key, try holding the key for a few seconds and see if it will stay running as long as you are holding the key (the starter will make a grinding sound while holding the key but won't hurt anything). If it stays running while you hold the key then dies when you release it, that indicates that the ignition switch is bad.
Jul 01, 2008 | 1992 Honda Accord
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
512 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
