Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
No power to the television
Hello my akai pt9588hd was working fine yesterday but this morning when i woke up to turn it on, the red light just blinks(below timer next to power button) and the picture dont come on there is no sound no nothing. I unpluggged the tv and plugged it into another power source and still the same thing occcurs...
  • 1 more comment
  • Sunset bum Dec 27, 2007
    same thing, what did you do...
  • Anonymous Jan 01, 2008
  • Anonymous Jan 10, 2008
    same problem
    Problem Solver:
  • 8 Answers
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Posted on Jan 28, 2008
A red power, a green timer, and a red lamp led lights are flashing on t front power panel.
Likely an AKAI DLP made actually by Samsung. All 3 lights blinking is lamp failure. You can fix yourself with owner's manual.
Sep 29, 2014 | Akai PT46DL10 46" HDTV-Ready Television
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have installed two woods cd500 series timers,for one month everything was fine came yesterday and no power to both timers. So started checking had power to both timers but red light was not on, so when i...
Usually when there is intermitent power like that there is a bad connection under one of the wirenuts. Remove the timers, untwist all wirenuts and start over.
Feb 11, 2012 | Woods Hardware & Accessories
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV not working
Check the lamp door assembly, if the lights are alternating red then green, then this might mean that the metal pin that looks like a roofing nail is not making contact with the metal clip. Remove screws, reset panel in place and turn on, the red power button should be the only light on.
Good Luck!!!
Aug 07, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
Aug 28, 2007 | Akai PTH5498 54" Rear Projection...
TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
May 02, 2007 | Toshiba 27AF41 27" TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
