Question about Garmin Nuvi 350 Car GPS Receiver
Antenna when raised does not pull in the satellites
I left the antenna in the parallel position for approx. 3 hrs and when I check the GPS, It was pulling in the satellites.
Posted on Oct 07, 2009
Antenna
The only reason to have an electrical wire going to the antenna is for a motor that raises and lowers the antenna. The antenna cable to the radio is the only wire on the antenna.
To replace the antenna, you have to remove it from where it connects onto the car, then lift it out from there. The antenna and the cable cannot be separated, it's all one piece. You pull the cable off of the back of radio, and tie a strong string onto it, because when you lift out the antenna, the cable will be pulled out from under the dash and to wherever the antenna is situated and out that hole. Now tie the string onto (hope you had a long string, lol) the end of the cable on your new antenna and cable, and stick the end of the cable into the antenna mounting hole. Pull the string from under the dash by the radio and you will bring the cable back into the dash and where you can plug it into the old radio and listen to good old music again !
Feb 13, 2013 | Suzuki Alto Cars & Trucks
My xm receiver says no signal - everything is connected properly - acct is up to date
With a Satellite Radio receivers you need to make sure the Antanna is on the top of the car. with nothing obstructing it. As it pulls the info from a Satellite. Now some bigger cities have terrestrial Antenna. But check the line for the Antenna make sure there is not bare wires showing and make sure that it is not damaged in any way.
Feb 28, 2011 | XM Radio (XMP6000)
Shows "updating". Never completes. Pulled power plug and retried. No help. Displays channel 0 until antenna is pluged in then updating. Displays "antenna failure" if antenna is unpluged during "updating".
Oct 11, 2010 | Pioneer SIR-PNR2 SIRIUS Radio Receiver
Won't turn on
try to replace the ac cord it maybe damaged when it was accidentally pulled out
May 05, 2010 | Sirius Boombox for Select Satellite Radio...
Antenna not found sirius satellite radio
You may have a defective satellite antenna or cable
Nov 09, 2009 | Sirius Satellite Radio Receiver
Garmin nuvi starting location is wrong
I tried to fix a problem similar to this for 1and 1/2 hours. Ahhh! However, after raising the antenna, (in back of device), the satellite picked up my exact location. Hope this helps.
Nov 23, 2008 | Garmin Nuvi 350 Car GPS Receiver
Sirius Antenna
Best suggestion for this is to put the antenna on top of house. First off, you need to realize where you live...the satellites circulate in a figure 8 across the middle of USA and Partial in Canada...if you live over on the East face the antenna East like...if on the West, then face it West...North, South...make sure not to bend your wirling lines what so ever they can be damaged. Tapper to side of house gently. Do not hammer down hard or add to much pressure to the wires over all when you are done call that 800 to activate...you will be ask to give them the sn or product number to do this should be on the bottom of the box of your radio or on the sticker...they will then attempt to send a signal to your radial shortly after..keep in mind some times this takes any where from a min to 15mins...if nothing by that time, they will start the trouble shooting process on the wiring. Have fun!
May 08, 2008 | Audio Players & Recorders
Getting to my radio's antenna plug
Depends on the radio but with most models when you bought it new you would have gotten two flat strips pieces of metal which should be inserted left and right between the radio and the radio bay. They will push aside the spring locks and then you can gently pull it out.
Some info here and here and on google ofcourse :)
Jan 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
NO SIGNAL all of a sudden. Gone. Lost.
Hey adam, check that antenna wire! It's probably pulling out at the antenna/magnet end. Adam, I checked that and sure enough, it was pulling out. So I put on a new antenna and problem solved! Thanks Adam!
Mar 20, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
Garmin Nuvi 350 Car GPS Receiver Logo
29 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
