Question about Nokia 6233 Cellular Phone
Nokia 6233 restarts
My nokia 6233 starts only for 10 secs.
Ok, this happened once again when I was changing a theme, it simply blocked and turned off. After that I kept turning it on and on but it was bugged : like it looks ok, then the screen becomes white with lines and then it turns off. I fixed it by taking out the memory card and putting it back again
But now the same thing happened probably because I turned off my phone by removing the battery instead of turning it off with the button. I mean come on, how sensitive is this fucking phone!? Isn't there a way I can reset it or something. The trick with the memory card doesn't work anymore. This phone is so buggy.
note that i have tried this *#7780# but doesnt worked but i m able to see my imei
Re: nokia 6233 restarts
Sorry, i dont have a solution either but am searching the net for one since my 6233 did eaxactly the same last ight on christmas when i hot swapped the micro sd card. it boots into a white screen with just the battery indicator, then either does nothing or just swithes off. If im lucky ill ge the signal inidicator and time displayed but for only a second or so before reverting back to the white screen or switching off. Ive tried the *#7780# but displays result unknown. Ive tried the firmware version display code but that shows nothing also. Also nothing on the IMEI code.
Ive also tried the other methods described above of taking the abttery out and sim out and micro sd out and the combinations of that but still nothing.
Any other suggestions?
Posted on Dec 26, 2007
  • 39 Answers
Have you tried starting up the phone with out your sim and/or memory card? Try using the memory card in a computer (you can get usb adapters).
Posted on Dec 23, 2007
  • 108 Answers
If your phone Built with Symbian operating system. Use *#7370# to Format the phone memory. if your phone could not even Boot up. Use 3 key trick Hard formating technique. before switching on your phone. Hold 3 & * & green dial button & on/off button simultaneously. Just make it a try. if fails Contact authorised service centre.
0 characters
3 Points
I downloaded a theme from another nokia phone.. Then, when i restarted the phone the screen becomes white and it just jams... What should i do?? Can my phone be formatted?
you must restart you phone just here the step
1st restart your phone 2nd after you restart just click the gallery where you have themes 3rd then change it
you need to do it you can
hope it will help you
Jul 17, 2011 | Nokia 6233 Cellular Phone
My Nokia 6233 Hangs & Then Shuts Down.
check the side button PTT
and make full reset
May 11, 2010 | Nokia 6233 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Mobile phone problem
there is no wallpaper as such for Nokia 1209, but still some good patterns you can change to under themes in display settings and once you go to themes you can select a theme and edit its wallpapers but only in-built once!
reply and rate please! and ask for any more support!
Feb 14, 2009 | Nokia 6233 Cellular Phone
Cannot change theme in Nokia 6233
For changing themes in 6233 phone memory equla to size of theme should be free. For ex. - if theme size is 215kb then phone memory should also have 215 kb free space . Free some space in phone memory and then try. thank you
Oct 30, 2008 | Nokia 6233 Cellular Phone
Nokia 6233
try flashing the mobile phone firmware that should correct the 10 sec boot up
Dec 25, 2007 | Nokia 6233 Cellular Phone
6233 cannot start
what you need to do is have the firmware reflash on the can do that with a nokia updater software or you can take the phone to a professional mobile repair shop and have them refalsh it for you to correct the issue ith the phone.
Dec 24, 2007 | Nokia 6233 Cellular Phone
Nokia 6233 most wanted solution
remove the memory card then turn on and then reset.
remove the sim card and then reset.
Dec 23, 2007 | Nokia 6233 Cellular Phone
Restarting problem
restore facrory settings by dialing *7780# or *7370# . remove newly installed java applictions also. also check ur phone memory wheher its ful
Dec 22, 2007 | Nokia 6233 Cellular Phone
6233 turns on for 10 secs and then turns off
I think you have a screen prob more than anything else
or even software problems.
Unfortunatelly ou will need to have a tech look at it.
OH try a master reset first if you can get it to stay on long enough that is.
Nov 07, 2007 | Nokia 6233 Cellular Phone
Nokia 6233 Cellular Phone Logo
212 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
