Question about Kohler Home
The seat uses expansion type bolts. the prongs have corroded. had to hacksaw bolts to remove. local hardware store has no such bolt, can I get them from you?
    President:
  • 1,865 Answers
I'm not quite sure what bolts you are seeking. Most toilets have two holes for the mounting of the seat, and any nut & bolt combo should work
Posted on Oct 06, 2009
  • jfox36 Feb 10, 2011
    You are looking for TOTO Part No. THU651N Top Tightening Seat Mounting Bolts
    Sold by: Guillens Enterprises, Inc.
How do i remove a broken bolt which is embedded in the toilet, the bolt keeps the toilet seat lid fastened to the toilet?
There has to be either a nut and washer under the toilet, or if its reversed a bolt head with a washer under it holding it down. To remove it you can either use a hacksaw blade between the bowl and the bottom of the seat. Or use a dremel tool to slowly cut away the metal rod, etc., from the top. If using hacksaw put down some masking tape on the bowl so you don't scar up the enamel surfacr of the bowl. Work slowly and you will eventulaly cut through it.
Aug 16, 2014 | Crane Plumbing Home
Wife's diability require raising passenger seat 2 inches
Remove one seat bolt. Get a replacement bolt 2 inches longer at any hardware store. Spacers can be made with a stack of nuts slightly larger that the threads of the bolt.
Jan 28, 2014 | Hyundai 2012 Santa Fe GLS FWD
Trying to remove Porcher Posh BTW toilet. Screws in side of bottom unit do not "undo". They are loose but do not unscrew from base. I have loosened cistern but that is all - "loosen". Screws again undo but...
Removing toilet seat hardware can be a problem, especially as it is prone to corrosion - but it can be done. You can attach a pair of gripping pliers to the nut, apply thread lubricant, and unscrew the bolt from the top OR you can use one of those blade-and-handle hacksaws to cut off the nut OR you can use that little hacksaw to cut off enough excess bolt length to allow a socket to engage the nut and allow the bolt to be removed from the top.
Oct 31, 2013 | Porcher Home
Now i wanna changing my Kohler3384 with a new seat,but how can i remove two old bolts?
The attaching hardware (not bolts) is removed by removing the nuts from underneath. You should be aware that on some old toilet installations the hardware may be rusted and the nuts difficult to remove. In that case, you may need to use rust solvent and even a hacksaw to get results.
Oct 13, 2013 | Cars & Trucks
The two bolts that holds the toilet bowl down. one on each side. the whole things turn ad i cannot take it off
a lots of the time when that happens you will need to use a grinder or a ' Dremil ' tool to cut the bolts that are holding down the toilet and get some new bolts and re-install. **** there is also a chance that if you CAN turn the bolt itself from the top that you can get the bottom of the bolt ( which is ' T ' shaped ) to turn in the right direction and get the bolt head to slip through the slots in the floor plate. since you will most likely need new bolts to re-install the toilet, go buy the new bolts at the hardware store and by looking at the bolts and looking at a floor plate at the store -- this will give you a idea of what you are trying to remove.. ( it is kinda like a puzzle ). ******
also --- sometimes you can get a hacksaw blade ( by itself -- not on handle ) to fit between the floor and toilet and cut the bolts that way,, this is kinda a pain to do, but in a pinch it sometimes works good.
I hope these ideas help you --- good luck ( ! ).
c...
Dec 31, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
How to stop seat from wobbling doesnt seem to have screws that fo into seat just a place for seat to sit on and then some cap to put over but nothing seems to tighten it.Im tired of falling off the toilet
First lift the covers off where the bolts should be (they should lift towards the tank). Are the bolts in place? If not, go to your neighborhood hardware store and look for replacement hardware. (Most stores will have staff willing to help you find the right parts.) Is the bowl damaged so that the holes seem large compared to the holes in the seat anchor points? Are the seat anchor points damaged?
The bolts should have nuts (and possibly washers, but not all models use them) underneath the bowl. Screw down the bolt while holding the nut from turning (so you need an adjustable wrench or appropriately sized wrench). Again see the local hardware store for the hardware if you do not have the nuts. Keep the seat centered as you tighten the bolts. (Alternate tightening until it is stable - do not tighten one bolt all the way down before doing the other side. You risk overtightening and cracking the bowl.)
I hope this helps.
(if the seat is damaged, you may want to replace it. If the bowl is damaged you must replace that.)
Jun 10, 2010 | Kohler - Toilet Seat - Moondance -...
Carbator spring is broke
Try your local hardware store, a good one should have an assortment (where they keep the nuts and bolts) of little springs, both types-compression and expansion, you might be able to find one that will work.
May 02, 2010 | McCulloch FHH25A Gas Pressure Washer
Toilet seat
Here's what I did. Unscrew them as much as possible. Then I used a bolt cutter and hacksaw to cut away as much of the plastic seat holders as possible. I could then remove most of the seat, and get better access to the screws. I then raised the loose screws enough to cut them with a bolt cutter. Soft screws cut easily. The screw heads are now out. Now, tap down on the screw/anchor and it falls into the bowl. It will stay there. The remaining problem is that you need anchors to secure the new toilet seat. Kohler wants $50. I have a usable but loose seat. Never again-Kohler.
I strongly recommend using a boltcutter. A hacksaw will tear up the bowl.
Nov 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Home Logo
119 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
