Question about Dell Inspiron 1526 Laptop
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you mean... another key and the f7 or just the f7, when I hit the f7 i get a message talking about Caret Browsing??? If I am to hit another key, which one is it?
  • 17 Answers
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start My touch pad is SUPER sensitive, when I type... - keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Posted on Oct 06, 2009
    Novelist:
  • 225 Answers
In dell laptops function key is the "Fn" key on the lower right corner of the keyboard beside control key. regarding the issue you are having try to change the mouse sensitivity settings from the control panel.
    President:
  • 2,600 Answers
You can set your touchpad sensitivity from the control panel. Start button > settings > control panel > Mouse > Look in the top tab for touchpad device. It should be the last tab on the right, click on it and highlight the touchpad listed. Look to the lower right and click on the settings button. When the window comes up, look in the cloumn listed and you will see a sensitivity title. Click on that and change the sensitivity of not only the pad, but the palmrest and buttons. Click apply when done and OK.
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Cursor jumping
I have had this same issue. I realized one day that the palm of my hand was touching the track pad intermittently. Some of the HP laptops have super sensitive track pads. Mine actually has a button that disables it for typing. let me know, if this helps.
Feb 26, 2013 | HP Computers & Internet
Cursor skips to earlier place in document while typing
I have had the same thing happen to myself . I have had to learn not to keep my thumbs so close to the touch pad of the laptop . The touch pad is very sensitive.
Dec 27, 2012 | Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
I need help disbling this touch pad
You need to look into the user information manual for that notebook to see if there is a disable function. If nothing else works, Place tape over the touchpad and that should help. Additionally, you can look at your mouse sensitivity settings in Windows under control panel and reduce the sensitivity of the mouse.
Jun 29, 2010 | ASUS Eee PC 701 Notebook
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
When I'm typing, the cursor moves
I think thats the best answer I have heard so far the control F9..it actually worked..Thank you very much!
This is the first msg I have typed since I have had the computer where the cursor hasnt jumped..
I tell ya these forums are the best
Thanks again
MIkey J
Apr 30, 2008 | Computers & Internet
Dell Inspiron 1526 Laptop Logo
1,769 people viewed this question
Alun Cox
