Question about Ruud UBHC Air Conditioner
My Rudd Achiever 10 ran on air setting flawlessly this summer. Now that I am using heat, I have a problem. I get heat into the house; however, the outside unit keeps shutting down after a few minutes of service and I keep having to walk outside to the unit to press the reset button. Can I troublehoot and fix this on my own?
    Problem Solver:
  • 6 Answers
The reset button usually is related to refrigerant pressures, and should be checked by an epa certified technician.
Posted on Oct 16, 2009
Rudd achiever heat pump will not come on. Fan works but no heat.
Possibly stuck reversing valve?? Does it cool well, just no heat?? Possibly low voltage wiring in tstat, did it work last year??
Dec 20, 2016 | Heating & Cooling
Can I change my ruud achiever 10 unit over to r134 an how
can you buy all new seals for your RUDD . r134A will eat out all the rubber ones in the system
Aug 12, 2016 | Ruud Heating & Cooling
I have a rudd UHLA-3617JA high achiever air handeler, works fine except the electric heater will not come fan starts normally, is this a fuse/breaker or failed electric element problem, how can i tell
It is either the element, sequencer (or contactor/relay), or power to the switching element. 5KW Elements normally Ohm out @ around 10 Ohms when they are good. Everything you need to check requires a multimeter.
Jan 21, 2015 | Heating & Cooling
I have a Rudd Achiever 10 . The unit was working yesterday morning, it stopped in the afternoon , and is still not working. The fan in the unit in the basement is working fine. Do you think it could just...
you will need to check you condenser unit(the outside unit) here is a website that may help,Tim:
http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-troubleshooting.html
May 30, 2011 | Ruud UBHC Air Conditioner
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
Rudd achiever 10 a/c will not kick on and some line is frozen in the unit.
The line will have to be thawed out with hair or air dryer. This may have frozen other components as well including a/c compressor relay or capacitor giving power to a/c compressor or motor unit
Jul 01, 2009 | Heating & Cooling
Rudd achiever serie. where do the 24 volt wires go to on the air handler.
The two wires from condensing unit go yellow or y from Tstat and theother wire goes brown if it is a Rudd or Rheem. Red from Air HAndler goes to Tstat R Green to Tstat G white to w. If it is digital tstat brown goes to C.
Jun 04, 2009 | Ruud UAMB Air Conditioner
Replace Rudd Achiever 10 ???
if the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
May 12, 2009 | Ruud UBHC Air Conditioner
Rudd Achiever A/C float switch is clogged.
If the pump was bad the switch is supposed to shut down the ac so the water damage won't occur. You most likely have a bad drain.
May 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Ruud UBHC Air Conditioner Logo
214 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
