Acer Aspire 5100 PC Notebook
Problem for Acer Aspire 5100 PC Notebook
My dvdburner of laptop hp pavilion DV2726CA reads any cd dvd but
By zohirg on Oct 06, 2009
can't burn, i tried all cd's dvd's brands =, -, i used different applications ashampoo burner, power to go , nero , but i still have same problem even with vsta caus e i istalled xp and vista anb both os it doesn't work can you help me i cleaned also the lens i think maybe the burner is dead i,v got this info
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.6.0
Internal Version: 8, 3, 6, 0
(Nero Express)
Recorder: <Slimtype DVD A DS8A1H> Version: WH66 - HA 1 TA 0 - 8.3.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <Slimtype DVD A DS8A1H >Version: WH66 - HA 1 TA 0 - 8.3.6.0
=== Scsi-Device-Map ===
CdRomPeripheral : Slimtype DVD A DS8A1H atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG HM250JI iaStor Port 2 ID 0 DMA: On
CdRomPeripheral : EDUJODI CLQJSH2RO5M7 1.03 a1k4hhzw Port 3 ID 0 DMA: Off
CdRomPeripheral : EDUJODI CLQJSH2RO5M7 1.03 a1k4hhzw Port 3 ID 1 DMA: Off
=== CDRom-Device-Map ===
Slimtype DVD A DS8A1H F: CdRom0
EDUJODI CLQJSH2RO5M7 I: CdRom1
EDUJODI CLQJSH2RO5M7 J: CdRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2038MB (2087212kB)
Free physical memory: 954MB (976916kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.10.2009
ISO compilation
11:14:36 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
11:14:36 #2 Text 0 File Isodoc.cpp, Line 6713
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
11:14:36 #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
11:14:37 #4 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
11:14:37 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
FSCTL_DISMOUNT_VOLUME
11:14:44 #29 Text 0 File Cdrdrv.cpp, Line 11450
DriveLocker: UnLockVolume completed
11:14:44 #30 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Comments:
Oct 12, 2009
- the main problem is writing not reading
it reads any cd but it can't burn
Solution #1
posted on Oct 09, 2009
Somewhat Helpful)
vpaaf
Rank: Wiz
Rating: 84%, 30 votes
Can use usethe drive to load data or write data and how about listening to music??
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5100 PC Notebook
Questions and Unsolved Problems for Acer Aspire 5100 PC Notebook
Do you recommend Acer Aspire 5100 PC Notebook?
Answer
Answer
hello i am having a problem when running a video, movies, clips. the problem is that the picture... (More)
Answer
Acer Aspire 5100 with AMD 64 Athlon x2 and Vista OS boots up &amp; loads normally, but keyboard,... (More)
Answer
pci device kepps popping up
Answer
i have a acer 5100 and the 4 way scroll button stoped working.
Answer
is it possible to install a built in microphone into an accer 5517-1208
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
