If Duplex printing is chosen as a default in a Xerox Laser Printer, and a print job is sent to the printer with only 1 side of printing. 1 What page count would be reported by the printer. 2 Is it even possible for a duplex printer to distinguis between a printed and no printed 'page'
  • 657 Answers
Xerox Printers do come with a sensor which detects the printed and blank papers.
Posted on Oct 06, 2009
How do you print two sided on xerox 6180 phaser
I expect you have to put the paper in the other side up. however if you do you could spoil the first side as it will melt the wax again when it's fusing the second side!
Good Luck.
Jul 31, 2014 | Xerox Phaser 6180N Laser Printer
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
Xerox Phaser 7760. Set document to print as double sided, and it prints single sided. Printing from Mac. Drivers up to date. Any ideas?
There are a few solutions to this problem.
1. The 7760 does not duplex from the MPT 2. The 7760 will not duplex certain paper types eg. envelope, transparency, labels, thick card stock,special. If your paper type is set to any of these it will default to simplex printing. 3. Conflicts in driver settings will cause the printer to default to simplex printing. 4. From the machine settings, duplex can be enabled or disabled. (Though driver settings should override this).
Hope this helps.
Jan 14, 2011 | Xerox Phaser 7760DN Laser Printer
Can you please tell me how to print double sided? Thanks
Xerox Phaser 8400 does not support double sided prints. You have to have a Duplex Unit for Phaser 8400 part number 097S03177 to be able to print double sided. If you have the duplex unit, on the Print dialog box just click Preferences and under 2-Sided Printing select 2-Sided Print then Apply.
Nov 16, 2010 | Xerox Phaser 8400 Laser Printer
Duplex printing problem
goto printer property and select 2 side printing .
Feb 26, 2010 | Xerox Phaser 4500DT Laser Printer
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Xerox phaser 6120 not duplex printing since it's wireless network
You have to go to printer properties and look for "optional functions" or something to that effect, and check the option "duplexing unit" or similar.
By default the computer does not know, that your printer has duplex capabilities.
Oct 27, 2009 | Xerox Phaser 8400 Laser Printer
How to set up printer to print double sided. Printer Xerox Phaser 8400
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Oct 22, 2009 | Xerox Phaser 8400 Laser Printer
Duplex printing problem with xerox 4500Dt
on your computer click start, select printer and faxes right click on your printer and select properties you should find the the duplex option is not said to be on your printer, change this. -Carl, please let me know if this helps.
Jun 04, 2009 | Xerox Phaser 4500DT Laser Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
122 people viewed this question
jasbo
jasbo
