Question about Marantz PMD331 CD Player
The drawer goes in very noisily...almost as if gear teeth are missing...the motor doesn't start up.
Didn't fix it, but decided that I wasn't in a position to spend money on questionable help with the only guarantee being that I'd have a tough time gettng my money back if I gave you my card number.
sorry, but that's the way it is.
Best
George
Posted on Oct 07, 2009
Stater spins but engine doesn' t turn over
Bummer. This is typically one of two things: starter drive, or teeth missing on the flywheel.
Of course, something can be cracked or loose, but surgery is the next step.
Feb 24, 2015 | Cars & Trucks
My montero sport makes a humming sound when I try an crank it, but does not start. Wha could be the problem?
firstly does the starter motor kick in , it could be that there are teeth missing on the ring gear in the gearbox , try putting the car in gear try 5th gear rock the car backwards and forwards and try start it again if the ring gear has a few teeth missing it should start after you have done this I hope this helps
Jan 31, 2014 | Mitsubishi Montero Sport Cars & Trucks
My stater is free,spinning thn grindingmon the stop but it doesnt do it all the ti,me but is slowly getting worste its a 2001 z3 roadster 3.0im i replaced the crank positioning sensor but did nothing...
replace the starter and the flywheel-the bad starter has not engaged the teeth on the flywheel fully and has ground some teeth off so you'll fit that space every once in a while-cheers Denny
Oct 31, 2013 | 1999 BMW Z3
Why is my newly installed starter sticking and smoking?
Some starter motors that continually miss engagement mash the ring gear teeth to the point that the pinion cannot disengage when the engine starts. This means that the starter becomes in effect a generator with uncomtrolled output. hence it overheats and burns. Have you checked that the teeth on the pinion of the new motor match the teeth on the ring gear. Ie are the teeth on one too course for the other
Jan 10, 2013 | Cars & Trucks
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
My older model Hobart n50 mixer stopped working. The motor is running but three teeth on the fiber gear were broken off from the main gear in the transmission. While removing some of the grease, I found...
The best solution I can give you is to become a member at the Hobart Corp. website and use there schematics to find where the pin goes. It is free to use the parts catologues have a parts blowup.
Follow the link below:
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FsalesZ2Fredirect.aspx&reason=2&formdir=2
Thank you for using FixYa, I hope this helps.
Jan 19, 2011 | Hobart N50 Stand Mixer
Grinding noise when ignition is turned
THe starter engages the fly wheel and in the process turns the motor over to cause it to crank. The grinding can be a bad starter causing the gear to either not engage fully or not disengage. It can also indicate missing teeth on the flywheel from damage from starter. If the car cranks and grinding goes away it points to the starter solenoid not engaging properly.. pushing gear into contact with flywheel. I would recommend replacing the starter and you can replace it with a good mechanical knowledge and DIY.
Jun 08, 2010 | 1997 Chevrolet Cavalier
Ford Mondeo 2.0 diesel 2002, starting motor was missing now just spins. Is it likely to be the dog gear on the starting motor or more seriously the flywheel teeth. This is not a solenoid issue as the...
I think you are on the right track. I would be inclined to suspect the starter and not the flywheel. The ring gear on the flywheel doesn't usually give any trouble unless it's been abused. Hope this helps.
Nov 12, 2009 | 2002 Ford SVT Focus
Not sure about the postion of the missing teeht and valve timing
when there are missing teeth on a cam gear the motor will never run. for as those teeth pass thru it puts the motor out of time again and again , and again
Feb 26, 2009 | 2001 Ducati 748 R
Marantz PMD331 CD Player Logo
67 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
