Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
The WD hard disk 160GB is not recognized after plugging into USB
The WD hard disk 160GB is not recognized after plugging in USB port. Blue light is on and disk seems like running. Please advice
  • Anonymous Mar 30, 2014
    Blue light is on, no noise, PC does not recognize
    President:
  • 2,030 Answers
It is very possible that your BIOS will not support a large hard drive. Without more information on your system it will be hard to diagnose your problem.
Posted on Oct 06, 2009
I have a simpletech harddirve 120 GB. Had it for about 2 years. The blue and red light usually appears and you could feel it run. Now theres no sound or moving parts and now only the red light appears. ...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Nov 10, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
WD HD TV Media Player won't recognize Hard Drive
I had a similar issue eventually reformatted on the mac and included the dos readable check option on snow leopard,
Jun 05, 2010 | Western Digital TV HD Media Player USB...
I have a WD portable 320G removable hardrive I can't get my computer to reconize it's plugged in. I tried changing the cords. No luck. Keeps trying to install then comes back unable do to either being...
Connect the external disk-drive to another computer.
If it still is not recognized, then you have a problem:
* the USB-to-disk-drive interface inside the case is faulty,
* the disk-drive inside the case is faulty.
If the former, disassemble the casing, and extract the disk-drive,
and temporarily connect it as an "internal" and "slave" disk-drive to your desktop, and see if you can read the files.
Dec 01, 2009 | Western Digital Computers & Internet
Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Oct 27, 2009 | Verbatim Computers & Internet
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
356 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
