Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Spin cycle won't work. Everything else is fine.
    President:
  • 1,865 Answers
Replace the timer controller
Posted on Oct 06, 2009
The spin mode on my washing machine has stopped working
The is a spin clutch soliniod which gets water on it ,rusts it up over time until it becomes seized.Replace!
Jan 15, 2016 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Ntw4501xq0 washer won't spin
You have a bad lid switch and it will need to be replaced. Here is the part to order. Below is a video to show you how to replace the switch.
Jan 21, 2013 | Amana NTW4501XQ
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
I have a whirlpool washer, model lsr7010pq1, and it won't spin on spin cycle. If I give it a spin by hand it will work. Agitation works fine, and the motor is running fine on spin. Could this be a belt...
when it gets to spin try to open and close the lid and see if it engages spin. if so the timer may not be pausing right before spin to allow the gear to drop and engage the spin cycle. it can also be a clutch or trans issue.you have to sit there through rinse and see if it pauses for a second a few seconds after it starts to drain if not it may be the timer which is common if its not pausing
Jun 06, 2011 | Washing Machines
Wm2455hw will not spin
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Apr 22, 2011 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
260 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
