Question about Fagor 5CFB-48 X Stainless Steel Kitchen Hood
Thermador Range Hood Intensive Speed Not Working
I have a chimney wall range hood HSW36TS that has a 3 speed motor with an intensive speed setting that boost the ventilation for 10 minutes and then reverts back to the last setting (low, med, high).
Just yesterday, when I press the intensive speed button, the fan goes to low speed, regardless of the current setting.
I'm trying to figure out the likely cause/fix for this. Is it likely the:
- motor?
- control board?
- switch panel (it is a logical touch panel)?
- capacitor?
Thanks!
2 Suggested Answers
SOURCE: Fagor 3CFT-90V Fan Intensive speed button- slows the fan down!
Does anyone have an answer?
Posted on Oct 10, 2009
I have a Best K41-1 and my variable speed on the blower does not work. It only works on high speed when slid into that position. What could be the problem?
I have the same problem (again) but with the lights not working also so something else is going on. The usual fix for the fan on high issue is to replace the switch assembly (SB06105117). It's an $80 part. This worked for me the first time it happened. If you are handy then it's a 1/2 hour project - turn the power off at the breaker.
Mar 18, 2012 | Broan-NuTone Best by Broan 30quot; 500 cfm...
My rangemaster cooker hoos has just stopped working.. no fan working and no light coming on ??
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 20, 2010 | Rangemaster Kitchen Hood
How long can the ducting be?
The ducting can be up to 50 feet in length.
Good Luck
Jul 30, 2010 | Miele DA5190W 36'' Wall Mount Chimney Hood...
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
No instructions nor fixings with cooker hood. How do we attatch it? How do we get hold of fixings as staff at wicks were useless. Cookerhood EFC90950X zanussi
you will have to place a straight edge on the top on the hood near the exhaust pipe then mesure from the floor to the bottom of the straight edge, that will give you depth then here is the demisons you have to build the box in. And if you don't have the power there you need to get a contrator or do it yourselfer to install it four you.
Price Range:£342 — £2,084 Average Price:£673 —— Colour body Stainless Steel. Body Material Stainless Steel. Colour chimney Stainless Steel. Typology Built-In. Motor location Integrated Motor. Operating Mode Convertible. Connection Rating (W) 225. Voltage (V) 230. Frequency (Hz) 50. Approval certificates IMQ. Length electrical supply cord (cm) 190. Height of the chimney (mm) 815/1970. Height of product, without chimney (mm) 815. Dimensions of the product, with chimney (if exists) (mm) 815-1970X898X490. Dimensions of the packed product...
Aug 21, 2009 | Electrolux Kitchen Ranges
Fagor 5CFB-48 X Stainless Steel Kitchen Hood Logo
124 people viewed this question
Top Fagor Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fagor Kitchen Range Expert? Answer questions, earn points and help others
