Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
I have a MTD Lawn Tractor and it has the 18HP Motor. It runs fine and has plenty of power. However, when I engage the mower deck the engine bogs down and then dies. Do you have any suggestions?
  • 437 Answers
May be time for a tune up; Change spark plug; Air filter; oil, fuel filter. It may be starving for air or fuel.
Posted on Oct 06, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
I have a 42" mtd lawn tractor. The blades do not
The blades engage via a belt, that goes around a series of pullies, one of those pullies is a tension pulley that is connected to your pto lever by springs, the engine has nothing to do with your blades until after you engage the lever, I would check your belt. It could be loose, and if you engage the blades it could take it a few to get up to speed, thus making it seem like its only when the engine is warm.
Does everything else work fine? As in the tractor moves when the blades are not engaged?
Jul 11, 2012 | Garden
Hi there i have an 18hp 42'cut power kraft deck probleme
Hi ! I have the same mower. It is an older machine and possibly the belt that drives the mower is worn. The belt drive is spring loaded and when you engage the mower by lowering the lever, aspring pulls the deck backwards against the blade. If the belt hasn't been replaced in a while, I would start with that first.
Apr 08, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
393 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
