Question about Acer AL2016WBbd Monitor
Is it compatible with the xbox 360?
Could I hook a xbox 360 to this and get HD?
0 characters
1 Points
Trying to hook up xbox 360 to computer monitor
Unless you monitor is HDMI capable I don't think it is possible without some sort of adapter.
Jan 19, 2014 | Acer P205H Widescreen LCD Monitor
I can not have my xbox 360 video show up on a pioneer plasma display AXD1460 tv
Do you want to just directly hook up the 360 to the TV? If so, check to make sure your TV supports component cables, which are color coded red, blue, and green.
If it's a recently purchased tv (maybe no later than say 4 years ago), it should support it.
Simply connect the cables to their respective inputs based on the matching colors.
Since it's going to be directly connected to the TV, change the Input using your remote to Component. (This button's usually located near the bottom or middle of your remote control.) Hope that helps, sort of :/ wish I had a clearer picture of the back of your TV so I can see what I'm dealing with lol.
Oct 08, 2012 | Computer Monitors
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
Viewsonic VX2260wm has a shadow on the right side of the screen
install an AGP card in the AGP slot because internal display card of the motherboard does not support to high resolution because of insufficient memory . use 8X display card for the better result ..
Apr 18, 2010 | ViewSonic X Series VX2260wm 21.5"...
Im trying to hook one of these up to an xbox 360, is it possible to do so via hdmi cable, or just via vga?
hi if you have an xbox elite the you can do it via hdmi cable, but if you have the normal xbox360 then its just the vga plug ime affraid hope this helps
Feb 22, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
I tried to hook up my ps3 to my hannspree monitor
did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
Oct 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Acer AL2016WBbd Monitor Logo
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
