Question about Canon PowerShot S3 IS Digital Camera
USB to Computer not connecting
Card is not old, not corrupt as it is still able to be read through the display back on the camera itself. We've tried 3 different cords, 3 different computers, and device manager for My Computer-still unrecognizable.
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Oct 06, 2009
Canon 40D unable to transfer files to my computer
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Mar 03, 2013 | Canon EOS 40D Digital Camera
WHEN UPLOADING PHOTOS ONTO LAPTOP GIVES 8004201F
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Aug 28, 2012 | FUJIFILM AX250 Digital Camera
Camera and laptops cant read my sd card,how do i get my card in place again?
There should be no problem using the card in a Mac, so this is a coincidence. Unless you've damaged your card with static electricity, there must be some corruption of the data. I suggest using a program like PhotoRec to try to recover the photos. After this, success or failure, please format the card in the camera for fewest problems going forward.
Jul 31, 2012 | Canon EOS 600D Rebel T3i Digital Camera
After formatting a memory card (any memory card) the camera works fine. I can take the SD card out and via an USB reader d/l the photos to either Windows or Linux. After use the card is no longer...
Sounds like you're yanking the card or card reader out without using the "safely remove hardware" function on your computer. This habit can corrupt the card (as you've found out).
Sep 19, 2011 | Vivitar ViviCam 5024 Digital Camera
My kodak C190 share camera keeps givig me an erro message for the memory card. It tells me it needs formatting and when I floow prompts it goes baxk to the same error message.
Hi
You do not actually say if you have ever had the card working in the Kodak EasyShare C190 but if the card has worked in the past and is now giving the error it could be down to corruption.
Flash memory cards can become corrupted for a number of reasons - the most common being:
1. the card is removed whilst the camera is still reading or writing to it
2. the power fails when the card is being written to or read from.
Corruption can sometimes be fixed by re-formating the card using a USB card reader attached to a computer. Most cameras will provide a re-format option (which sounds as if you have tried) but all this format does it to relay the directory structure on the card - if the card is corrupted this will not be solved.
Formatting the card in the USB reader will wipe the card of all data - NOTE, any images that were on the card will be lost forever.
If this does not solve the issue I would suggest you try another card to narrow down the fault to the card or the camera itself.
I hope this helps to solve your problem
David
Feb 13, 2011 | Kodak Easyshare C190 12MP Digital Camera...
I can't download pictures from my Samsung i8 camera. It might be the USB connection to my laptop? I've tried to use 2 cables provided (joined together) to make a connection, but the laptop isn't...
Will it work on another computer? If so, it's probably a corrupt driver. If the camera is working fine, you may want to just use a memory card reader instead. They are inexpensive and read pictures faster than the camera itself. It is an extra step to remove the card each time but is less than a new camera.
Feb 03, 2011 | Samsung i8 Digital Camera
Although my memory card is 75% full, my screen reads "there are no files"...I am able to display the files on a computer however. When new pix are taken they are stored and can be displayed. I've tried...
Writing to a camera card using a computer will corrupt the card 99% of the time. It will begin to give strange readings (as you have experienced) and will eventually corrupt the camera you try to play it in. I suggest you use a card reader and download your pics to your computer. Then, format the card in the camera to completely erase it and optimize it for the camera.
Aug 17, 2010 | Olympus Stylus / mju 1040 Digital Camera
I uploaded my pictures from my memory card onto the computer. When I put the card back into my camera, the camera won't read the memory card and it says the internal memory is full (12 pictures). How do...
If you indeed have the pictures on your computer (and are safely stored)... you might try selecting the format memory card function in the camera, to reformat the card, in case it was somehow corrupted while connected to the computer.
Aug 09, 2009 | Kodak EasyShare M853 Digital Camera
SOMEONE HELP!!!
Check the camera menus. There are several connection types.
Aug 08, 2009 | Polaroid I533P Digital Camera
Moving photos
Sorry, no. You can use a card reader to put the pictures on the card. Bear in mind that if you've done any editing on the photos then the camera may not display them.
Dec 10, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot S3 IS Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
