Question about Seagate (ST3160827AS) 160 GB Hard Drive
Hard Disk Drive Not Detected
I have 160 GB SATA Seagte HDD, suddenly it stopped woring & giving a message Boot drive fail, when i tried to reload the Win XP, I received message no HDD found. Kindly give me some solution, my HDD is still under warranty period. I contacted the vendor he told that he will replace the HDD but no guarntee for Data
  • 70 Answers
Does your hard drive get detected in the BIOS? If yes then you can recover data by plugging that hard drive as secondary and running a recovery application like Recover My Files.
Posted on Dec 24, 2007
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
SMART stands for "Self Monitoring and Reporting Technology".
You BIOS has detected a pending error in your hard drive.
take the hard drive out and use an enclosure to extract all the data you might want to take out of it soon, since that hard drive is failing.
If possible, try going into the BIOS and disabling SMART, so you can boot into Windows and copy all the necessary files you want to get off of the hard drive.
Removing the hard drive would ultimately get rid of this problem though
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
Navigate the BIOS menu using your arrow keys and use the on-screen legend for reference on how to change settings.
Look for a menu titled "Hardware" "Hard disk" or something similar. You are looking for an option that references "S.M.A.R.T."
Highlight the "S.M.A.R.T" option and set it to "Disabled" or "Off." Once you have changed the setting, choose "Save and Exit" from the menu or press the keyboard key corresponding to it (as listed in the legend).
Select "Yes" or press "Y" when the BIOS asks you to confirm your choice.
hope this helps
Jul 06, 2012 | Seagate Technology Barracuda 720012...
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Mar 19, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
Boot device
your hard disk has upto 3 years warranty from the day of purchase
May 26, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hdd is not getting detected it is new hard disk the hdd is 160 Gb,cables are good solution to be not to open hard disk
u have installed the hdd properly
but not the bios..
open biios
press <del> or the key suggested by the computer when the computer boots.
u will enter bios...
now go to boot section
make first boot as the hdd shown in the list....
save the settings and reboot.
if it fails ..
unplug ur hdd. a and plug it again...
and follow the instruction again
Mar 11, 2010 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Error in loading Operting System
you can download and create a "repair" disk that will be able to scan your hardware without the need of windows. click here to download the disk, unzip it and create a disk.
follow the directions in the setup menus.
from the sounds of it your boot sector has become corrupt
good luck
Mar 12, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hard disk detection problem
ALL hard drive eventually fail, I suspect yours is failing, I strongly suggest you backup all your data. Here is a free software that will tell you about your hard drives health.
Oct 05, 2017 | Seagate Barracuda 7200.10 ST3250310AS SATA...
SumsungHDD Fails to load OS
Have you got a decent spinup?
Are the rest of the drives working properly, if they are not it may suggest faulty PSU.
Try connecting to a diffrent pc, or purchase a USB sata convertor
Aug 13, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
249 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
