Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
I have already replaced the bulb on my toshiba 42HM66 projection
After I changed the bulb and plugged back in the green power light blinked and the lamp was blinking orange and tv didn't come on so now I am replacing the ballast and would like instructions on how to do this?
I replaced the lamp on my toshiba 42HM66 and that worked for about 2 weeks. I ordered a new lamp and replaced it. Now the lamp light blinks amber and then the power light blinks green at about 30 second...
You will need to check if the output supply going to the lamp is good. If not the ballast will need replacement. That model is actually famous for haveing ballast issues. You can get the replacement ballast from www.tvcircuitboards.com they also assist with installation assistance if you require it.
Nov 07, 2012 | Toshiba 62HM95 62" DLP HDTV
Toshiba 42HM66 has a whirring noise that stops when power off
this is a bad color wheel, however you cannot just change the color wheel on this set you have to replace the entire light engine.
Dec 06, 2009 | Toshiba 42HM66 42" Projection HDTV
Plugged in our rear projection tv and the picture is orange and green! why
If you are using the color stream input make sure the correct color wires are plugged in the same on both ends. if color is off on all inputs and the TV menu then replace the light engine.
Nov 14, 2009 | Toshiba 42HM66 42" Projection HDTV
Toshiba 42HM66 and it shuts off on its own. Im not sure if its getting hot or if the bulb needs to be replaced. It will just shut off at any moment without the 10 sec countdown that happens when I manually...
remove bulb and place in freezer for 5 minutes. the when unit comes on, go into menu and find lamp setting. select and it will ask you if you replaced bulb. select yes which resets the lamp time to zero hours
Nov 10, 2009 | Toshiba 42HM66 42" Projection HDTV
Keeps turning off by itself after about 30 minutes
Is your air intake clean or clogged.. Maybe it's overheating causing it to shut off.. Had the same problem didn't replace the bulb but cleaned the intake and it works great again. Worth a try.. Intake is located on the left back pannel of the tv.. outside pannel pops off easly.
Apr 27, 2009 | Toshiba 42HM66 42" Projection HDTV
42hm66 toshiba picture quality
I would change the bulb out, if it's not that at least you have a spare when it does go.
do you know how many hours are on your bulb?
good luck
please mark the post with a fixya
Mar 17, 2008 | Toshiba 42HM66 42" Projection HDTV
42HN66
i would ask for a refund or exchange.
Dec 29, 2007 | Toshiba 42HM66 42" Projection HDTV
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
477 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
