Question about HP LaserJet 2550L Printer
Paper will not feed. all three lights are on
Paper will not feed. all three lights are on steady.
  • bengan Nov 16, 2009
    My Hp 2550L does´nt take the paper. After a second press on the green buttom I get this:
    Start, ready and varninglamps are lightning.
    What to do?
    Swejack
  • 81 Answers
The printer has encountered a service error. You need to press and hold the Green Go button to see a secondary error light configuration.If you can repost after you have done this i will be able to tell you where the fault lies.
Posted on Oct 13, 2009
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
Manual paper feed works but not automatic feed.
I've been told labels have to be manually fed on that printer.
Mar 30, 2010 | Brother HL 2140 Laser Printer
Red Error light is on, what is this error and how to get out of it?
If the light is steady (not flashing), it means a paper problem. Either the paper tray is empty, or maybe the document you're trying to print is set to 'manual feed.' If the latter, then modify the page setup in properties, to use the defult paper tray.
Oct 06, 2009 | Brother HL 2140 Laser Printer
Paper does not feed all Malfxn lights on
Can you tell if the feed rollers are turning? Depending on what type of printer it is, you feed rollers could be worn and not picking up the paper.
Feb 27, 2009 | HP LaserJet 5p Printer
Steady red light feed paper button
your printer needs to be reset put this in google scc download it and that should work
Nov 23, 2008 | Epson Stylus Photo 1290 InkJet Printer
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
HP LaserJet 2550L Printer Logo
149 people viewed this question
Seeker5211
Seeker5211
