Question about Philips DVDR72 Progressive-Scan DVD Recorder
I get Disc Error while recording. Why
I cleaned the laser lens and the problem went away
Posted on Oct 07, 2009
Emerson EWR10D5 DVD Recorder/Player - using 16x DVD-R I get an error while recording
Sounds like a bad disc. You may also want to clean the laser lens with a cleaner disc just to be sure.
Sep 07, 2017 | Emerson Televison & Video
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
When i put disc in it says disc error
the laser is not being able to read the disc put a cleaner disc through it or get it pro cleaned
Jul 06, 2010 | Philips CDR796 2-Disc CD Recorder
My protron dvd recorder is saying disc error, when
Hi
This could a dirty lazer bulb try cleaning with a damp shammy leather allow to dry for a few min's . if this does not clear fauly lazer unit will need replacing
regards windyhouse
Mar 29, 2010 | Protron PD-DVR100 DVD Recorder
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
It wont finalize disc just says disc error
Sounds like a duff (dirty or scratched) disc. Try another one.
Jul 08, 2009 | Philips CDR770 CD Recorder
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Disc error
after recording, did you ensure the "finalize" or "lead-out" process completed?
May 25, 2007 | Philips DVP642 DVD Player
Philips DVDR72 Progressive-Scan DVD Recorder Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
