Question about Nokia 3315 Cellular Phone
No power no signal - Nokia 3315 Cellular Phone
  • 78 Answers
YOUR CELL SIGNAL AND POWER IC IS DAMAGED CHANGE IT
Posted on Oct 06, 2009
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
1998 monte carlo brake lights dont come on
This is fairly easy to diagnose. Down by the brake pedal there is a switch. You may have to remove some trim panels to access it. There should be one wire with power all the time. There should be another wire that has power only when the brake pedal is depressed. If there is no power on any of the other wires with the brake pedal depressed than the switch is bad.
If there is power than the more common problem is the turn signal switch. I know it doesn't sound like it could be the problem but let me explain how it works. the turn signal and the brake use the same bulb. In order for the correct power source, brake lights or turn signals, to get to the correct bulb the turn signal switch is used. If you are not turning the power from the brake switch is routed through the turn signal switch and then sent to the two brake brake bulbs. If you are turning to the right power from the brake switch is cancelled to the right bulb and replaced by power from the turn signal flasher.
One quick way is to see if the third brake light is working. If it is you know the brake switch is working since power to the third brake light bypasses the turn signal switch.
Good Luck and let me know how it goes!
Aug 14, 2015 | Cars & Trucks
The attention of a signal is 12db what is the final signal power if it was originally 4w
If the original signal was 4 Watts, and the increase is 12dB, the increase is a factor of 16 which will give you 64 Watts as a final signal power. Power doubles for every 3dB.
Nov 20, 2013 | Computers & Internet
2000 tacoma flashers don't work but turn sig do work!
The hazard switch gets power from the horn fuse which is hot all the time, and from the turn signal fuse which is hot when the key switch is on. The turn signal switch gets power from the hazard switch and both use the same flasher.
So if the turn signals work but the hazard switch does not power the lights, and both fuses have power, I would say the problem is inside the hazard switch.
Feb 19, 2013 | Cars & Trucks
Canon ir 2220 ERROR CODE E261
U NEED TO INVESTIGATE
the input/output ports of the DC controller PCBs.
COPIER>I/O>DC-CON<DC-CON (5/7)>
P020 xxxxxxxxxxxxxxxx=runs from left to right 15>0
ADDRESS=P020
BIT-
0- zero-cross signal -
1- heater trigger 1 signal 0: ON
2- heater trigger 2 signal 0: ON
3- heater error OFF signal 0: error
4- not used
5- not used
6- M9 registration motor phase A pulse signal -
7- M9 registration motor phase B pulse signal -
E261 0000
The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected?
(zero-cross signal: J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Jan 22, 2013 | Office Equipment & Supplies
Front left turn signal doesnt work
The turn signal circuit is different from the parking lights. So the headlights would not be involved.
You should have power on one side of the bulb for parking lights and the other for turn signals.
If you have no power for the turn signal circuit, I would look at the turn signal switch. It powers each bulb separately.
Aug 21, 2012 | 2005 Saturn Ion 2
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
There is no power signal
then it's network is nt working properly. .
check that. .
Aug 10, 2009 | Nokia 6610i Cellular Phone
Nokia 3315 Cellular Phone Logo
101 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
