Can't program remote control...
I have a new sharp aquos 32" TV & I'm trying to get the remote to work the comcast digital cable box...the manual for the tv doesn't have a code it...
I need some help...trying to figure that one out ;-)
tons of thanks!
Lucy
  • davykat Jan 30, 2009
    I talked to a very helpful person at Comcast and she told me that with the brand new tv models, the codes they have in their documentation are obsolete. She said that I should call every month or so to find out if they've updated their codes yet. She said that they've had a lot of calls since the first of the year (probably Christmas TVs) because the Comcast remotes can't be programmed. So, if you're having this problem, you aren't alone. I guess we just have to be patient.
The code is 11602. BUT, with OPC on it works only until it gets dark. Then I have to place alu foil over the right side of the box to keep it working.
Posted on Jan 10, 2009
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LCD tv "Audio window" keeps popping up on the corner
Replacing the cable box may fix the problem. But, you're the 4th person to have this same problem with this SHARP TV MONO only audio.
Try system reset button on the back of the TV or the box.
Feb 17, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Jul 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Arrow keys
buy a remote for your sharp....
Jan 25, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
Televison & Video Logo
418 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
