Question about Campbell Hausfeld 3 1/2" Rh Fram Nailer
Trouble finding 3 1/2 clipped head nails 34 degrees
I can't seem to find a supplier for the nails reccommended for the CH framer air nailer . anybody found a source?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You can use the same nails that are used for these nailers: Porter Cable FC 350A, Hitachi NR83AA2, Senco FramePro 701XP, 751XP ,Ridgid R350CHA, DeWalt D51822, D51823, and Paslode F-3505. Make sure you purchase the correct shank nail. Nail length should be 2"- 3 1/2" and the shank should be .113" - .131". I have purchased nails for my FC350 at Home Depot and they are relatively inexpensive. Though you have to buy a case of like 2000 or 4000. The brand of nail is Grip Rite that I purchased. Any questions please post.
Posted on Oct 15, 2009
My CH just started misfiring, it will put one nail in, then it will fire but not expend the nail. It has worked fine, put a 80' of fence last week, now it will put out a nail, miss, then put out another, is there an adjustment I need to make, lube a part? I have been using Grip Rite collated framing nails, 21 degree round head, ring shank. thanks
Posted on Jul 05, 2010
What degree nails to use?
Your gun uses 22 degree round head plastic strip nails. Most likely nail that is easy to find in stores is 21 degree nails for Hitachi , Duo Fast and others. Both work ok.
Apr 03, 2013 | Porter Cable Cable No. FR350A Rnd Head...
What degree nails
Hi, Senco 601's use a 34 Degree Strip nail. Easiest way to remember is this when thinking of Senco strip nailers:
601 and 651 are 34 Degree clipped head nails
602 and 652 are 20 Degree FULL round head nails
www.collatedfasteners.co.uk
Mar 17, 2013 | Senco & Frame Pro 601 Framing Nailer
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Can you use regular round head nails in the cliped nail version ?.
Your gun uses 30 -34 degree clip head paper tape. Order a sample of the nail below. It may work on your gun. These are offset full round head with paper tape. Safe way to test if nails will work is to remove the head of the gun and insert nails into rails. Push down on the driver with wood handle of hammer to eject nail. This will test for jamming or two nails trying to eject and cause jam. Look down barrel to see if the head is alighed correctly or too far from centerline of driver.
http://www.mazenails.com/catalog/catalog.php?page=PAGE04&group=PT34
Aug 24, 2011 | Porter Cable Cable No. FC350A Clipped Head...
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Can i use full round head 3-1/2 passlode nail in this nailer
The FC350A uses a 30- to 34-degree collated clipped head nail which is very similar to the Paslode 34-degree round head nail. Paslode's nails are unique because the round head nails collated very close together and the head of the nail is offset to the shaft unlike Porter Cable full round head are further apart and the head is centered on the nail. What does all this mean? The Paslode round head nail may work however the driver will deliver the blow off center to the shaft of the nail, This could cause the nail to bend as it enters hard wood and possibly jamb the gun. You should be able to exchange the nails (with small restock fee) at a major fastener store (not Lowes or etc. ) with out having purchased them at location because the Paslode nails are very popular and with todays economy the store will gain a new customer. If however you would like to try using the nails, try the following. Remove the head of the gun to expose the driver. Install the nails as usual and with **** of small hammer quickly and firmly push driver all the way down the cylinder to see if nail is easily pushed out of bottom of nose. (You can push driver back up with long thin screwdriver or allen) If successful, replace head and connect to air however lower pressure to 40-50 psi and nail into soft wood increassing the pressure little at a time with each test untill full pressure around 90-100psi. Good luck
Jul 19, 2010 | Porter Cable Cable No. FC350A Clipped Head...
What is the angle of the nail we use with this nailer
if thats a hitachi nr90ad, then you should be using 30 degree paper taped clipped headed nails,, never use plastic or wire collated nails in that gun,, some boxes might say 30 up to 34 degree and thats fine, also in a lot of areas clipped headed nails are no longer code, so they made the nails full headed, the head is just off set,,
Dec 04, 2009 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Just bought a senco pro 600 framer nailer what angle nail to use
My 600 uses 35 degree clipped head and is printed on the side of the magazine.
Mar 14, 2009 | Tools & Hardware - Others
What brands of nails will work in my 15ga finish nailer 1000993
Here are a few tips on buying nails for your nailer. Nails are sold in two basic categories, clip head and full round head. The clip head are lower in price and are usually taped on glued together with no spacing between them. The full round head have spacing between each nail and are held together with plastic. Some nailguns can use both types. It is important to verify the angle of your gun. To measure the exact angle use a straitedge along length of rails and a protractor at the barrel of the gun. Place the protractor on the barrel with the 90 and 0 degrees aligned with the barrel and hold the straitedge aligned with the rails and the 0 degree mark. Read the angle. You may find that your gun measures a different angle. Nails are sold from 0 to 34 degree. 34 degree is usually clip head for Paslode, Senco, Hitachi and other brands. I find that many brands of nails do not list the angle, but list the name of the gun instead. This makes it difficult for non-branded guns. Take the protractor into the store and measure the angle of the nails or place the nails on the outside of the rails to see if they align with the barrel. Shop several stores because nails vary by brand. Once you verify the perfect fit, ask for a sample strip to try in your gun. When you identify the angle and type, use this information to shop for price. Most nails are imported from around the world, however there are nails still produced in the US costing more. Home Depot and Lowes do not carry a full range of nails.
=Google the internet for more info on nails such as www.nailzone.com. They sell a 33 degree nail that may fit your gun. Good luck and email me or post again with more questions.
w
Jan 19, 2009 | Northern Industrial Tools Air Tools &...
Campbell Hausfeld 3 1/2" Rh Fram Nailer Logo
1,001 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
