Question about GE Ovens
How do i replace the cooktop light bulb in my microwave oven?
How do i replace the cooktop light bulb in my hotpoint microwave model RVM1435WH001?
I realized the light bulb was fixed using an adhesive (maybe a glue stick) that is why, I had a hard time removing the old bulb. After forcing it (and breaking the adhesive seal) I was able to replace it with a new one.
Posted on Oct 07, 2009
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Have a microwave oven Litchenaid model # KEMC307. The light bulb doesn't go on anymore and we would like to replace it. I assume it is a halogen with 2 prongs that pulls out but it is very hard to get a...
Ok, pull the oven out, remove the 2 screws on side trim of oven, remove the screws from trim under oven, now above the oven, remove the other 2 screws behind the grill. This should give you enough room to pull the unit forward. The bulb is on top. Hope this helps.
Jan 04, 2011 | KitchenAid KEMC307 Electric Double Oven
Hotpoint microwave wp900esp23s won't heat up light comes on and table turns but thats all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 14, 2010 | Hotpoint Ovens
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
Have to replace my hotpoint RVM1335WC 001. Need size, watt info
depending on age of microwave it could be 650watt,& 1.5cuft.
Sep 28, 2009 | Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Oven light bulb
Check your email
Jun 15, 2008 | Ovens
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Ovens Logo
416 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
