Question about HP PSC 950 All-In-One InkJet Printer
Its not responding and the warming up sign flashing for along time
Mine will do this... sometimes even after I just printed something! Sometimes I fix it by canceling the print job and then turning off the printer. Wait a few seconds and turn the printer back on then try again and it usually works. Other times all I have to do is "open" the printer as if I was going to change the ink cartridge and when I shut it back down, it will print without any more problems.
Posted on Oct 16, 2009
YN 565EX wont firing
I don't think this looks like any camera. But I know you can use this on a digital camera.
If the 565EX stops after 11 flashes, it could be it is warm. It could be the overheat sensor is a little bit to quick to respond. There also could be a problem with your batteries. If they run low in a short time, they cant deliver enough power to charge the Flash.
Try new batteries and be sure you charge them correct. Using an old charger with new (high capacity) rechargable batteries, is asking for trouble, because the old chargers can't charge modern batteries to full capacity.
Nov 06, 2013 | YONGNUO Cameras
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
Suzuki sidekick transmission - wont go into drive gear until warm
I have the same issue - the car cold will not shift out of first until the trans fluids are warmed for about 5 to 10 min. did anyone respond to your question?
Bill
RGRDonovan@aol.com
Nov 16, 2009 | 1992 Suzuki Sidekick
Corrupted uploader
Are you certain you DO HAVE a live Internet connection while you do this? Sounds as though the transfer has not started yet and the NOT RESPONDING message suggests your upload process may be waiting for a connection. Good luck!
Oct 30, 2009 | Microsoft Windows XP Professional SP2
Laptop will not respond to flash or dvdi
your hardware problem this is only correct when yyour system is open and remove its ram by this this memory will work and next time it will not do this
Jul 18, 2009 | E-Machines (T2958) PC Desktop
2003 Oldsmobile Alero Elec. Problems
the Body Control Module is bad. If your security light goes off later then most likely.
Mar 16, 2009 | 2003 Oldsmobile Alero
My surfline emits calcium? along with the steam from plate
Empty about half the water (guess) out of the iron pour in straight white vinegar. Warm the iron up then shut it off and let it sit for an hour or so, then pour out the water vinegar mixture, it should have a kot of white calcium particles in it, I would do this a couple of times to be sure, rinse thorougly.
The first time you use it after that use it on an old towel first just to be sure.
If this works for you please respond. Thanks
Feb 11, 2009 | Rowenta Surfline Iron DE-333 Iron
Slow key
I had this problem before. It is either water damage or theirs a short in your I/O port.
My solution is to leave it somewhere warm for about a day to get the water to evaporate. Take all the batteries/ faceplates/ ect off so that it doesn't stop teh water from staying in. Then after a day. Put everything back in and if it is still slow blow really hard into the I/O port and that should solve the problem.
Aug 23, 2008 | Texas Instruments TI-83 Plus Calculator
Flashing loading sign on window.
Greetings,
Does that happen on all or no CD/DVD at all ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 14, 2008 | Televison & Video
HP PSC 950 All-In-One InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
