Question about GE ZIRS36NMRH Refrigerator
Ge refrigerator model tfx24fge -at staggered intervels water is leaking from the bottom front right side. About a pint of water puddles on tile. Occurs anywhere from every 2 days to every 4 hours. thanks!
    President:
  • 1,462 Answers
HI,
Self-defrosting refrigerator/freezers have an evaporation pan in the bottom, and a small hose that carries the water to it. There are chances that hose get plugged or disconnected, and it lets water run out onto the floor or inside the fridge. It's unusual for the pan to get full and overflow, but it's possible..
The condensate water off of the evaporator drains into a plastic pan. It relies on the heat from the condenser/fan to evaporate this water. If the condenser coil under the fridge is clogged and the fan is not moving the required air, the water will not evaporate and the pan will overflow. Make sure the coil is clean underneath and the condenser fan is running with the compressor
Pull out the drawers in both the refrigerator and the freezer if there is water or Ice on the bottom there is a clog ...use a baby nose ****** and force hot water through the drain hole until it goes through well ...that should fix the problem
Please leave me comments,if you need further assistance
RNJ VINODKUMAR
Posted on Oct 06, 2009
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
GE Profile Side by Side frig leaks
Here is a lot of information on one page so take in the part that will help you stop the problem. Also you can contact me if you still have problems. Thanks Sea Breeze
appliancepartsse@yahoo.com
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
GE ZIRS36NMRH Refrigerator Logo
59 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
