Question about StarTech.com StarView SV211K 2-port KVM Switch
Whats new codes for chipped cable box?? - StarTech.com StarView SV211K 2-port KVM Switch
  • 4 Answers
Dsdsadsa
Posted on Oct 06, 2009
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
Movie channels and sports gone
Star View 3 The Box Super when channels discappear ;o)
1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Aug 26, 2009 | StarTech.com StarView SV211K 2-port KVM...
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
E74
If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
1) (Ideally) Send it back to microsoft
2) Get your board reflowed.
3) Try one of the X-clamp mods (following a motherboard reflow if at all possible.).
4) Take a heat-gun to your box
5) Try "the towel trick"
Feb 19, 2008 | Microsoft Xbox 360 Console
Substitute ink cartridges no longer work
I have the same problem and many Canon users , i try a trick that mayby solve this and last but not least ... Mayby the only cheap solution for all print users !! jumping-smiley-004.gif
My problem .. was looking for a cardrige solution ( IP4300 ) because 4 (of 5) cardrige leds are dimmed off and need to be replaced . I just order 5 adopters and 5 new with chip for all the five cardrige . Problem : The chip uses memory and that makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is new, experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need all 5 brandnew cardrige with chips ( please keep all ink preventions inplace )
B - You need is a 4 poles - 1.50 / 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - 5 old chips for adopting the connection outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of 1,5 / 2,5 meter a 5 pcs of 30 / 50 centimeter
2 ) Solder on each lengt a old chip (this is functioned as a adopter) but first remove all the (useless) electronic components and place them on the cardriges
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our make a alternative contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the empty old chips ) in the right ink location(s)
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for arrive of the new ones, anybody who try make a handshake !
See you soon
John
Netherlands
Jan 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Access code needed
Go to www.magnavox.com , and download the operators manual. You go to page 27-28 to Restore factory settings. This will remove old password.
Jan 24, 2008 | Philips 17MF200V Television
Need help to re-program Toshiba remote that came with MW20FM1
Check out Toshiba Customer Support. They e-mailed me the instructions to reset the V-Chip.
customer_support@tacp.com
Oct 15, 2007 | Toshiba MW20FM1 20 in. Combo
V-chip
have the cable company change the cable box it is the source of your problem.goodluck
Aug 04, 2007 | Orion1934 19" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
708 people viewed this question
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
