Question about Car Audio & Video
How to wire 2 opti1533d by lanzar with the optidrive 2000d amp? how do i wire them if i put 1 amp on each sub
    Genius:
  • 1,066 Answers
Your speakers are 1 ohm per voice coil, dual oice coil. your amp is no lower than 2 ohms stable mono.
the proper way to wire this so that you do not burn out the amp is to run the 2 vioce coils in series. run the positive lead from the amp into the positive lead of one of the voice coils, then run a jumper wire from the same voice coil's negative lead to the same speaker's 2nd voice coil's positive input. then run from the 2nd voice coil's negative back to the amplifier's negative speaker lead.
you will be running for each speaker/amplifier set: amp + to terminal set 1 +, terminal set 1 - to terminal set 2 +, then terminal set 2 - to amp -
Posted on Oct 09, 2009
How can I connect 2 15 (inch) Lanzar maxp15 subwoofers to a Lanzar 3000 watt 2 ohm mono block amp?
You need to find out the voice coil ohms and if you have 1 or 2 voice coils in each sub and then wire accordingly.
Apr 15, 2016 | Lanzar Car Audio & Video
Hi! I just inherited a Lanzar OptiDrive 1400D amp. Can anyone direct me to the Lanzar authorized or service centre in Singapore as I intend to send in for a general servicing. Thank you!
It appears that no identified service center exists in Singapore. You might want to try contacting Lanzar customer support directly for assistance: http://www.lanzar.com/ContactUs.aspx
Apr 17, 2015 | General Cell Phones
What is the best vented/ported box size for my 15 sub that will give maximum output and maybe even more?
Unbless you are building a wall...I would never give up my back seat. I built "The Pace-Maker" which won IASCA Enhanced SPL Nationals in 91,92,93 & 94.
Sep 30, 2011 | Lanzar OPTI1533D Car Subwoofer
Can I hook up 2 lanzar opti1532 subs 2 a kicker kx 1200.1 or do I need a bigger amp, its a 1ohm stable amp an birth sheet says 1390watts but they told me at 14+ volts it will do 1400rms
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
My Lanzar Optidrive plus has a green light and a red light. I assume this is a sign of safe mode. normally it is just green. How can i get it back to normal and in working order. I already tested other...
your output of the amplifier have been distorted. I suggest you take this to a reputable service technician that has experience with lanzar OptiDrive old school Rockford Fosgate or Orion. These technicians are hard to come by nowadays but they definitely are worth the money that they charge. I happen to be one of those such technicians.
Nov 15, 2010 | Lanzar OPTI 50c Car Audio Amplifier
Trying to install subs
If there is no red and black colored input wire connectors on the subs then it doesn't matter.Positive and negative does not really effect speakers and subs since it is DC anyways.
Jul 25, 2010 | Lanzar OPTI1533D Car Subwoofer
My amps and subs are working, but my subs aren't hitting.
Try bypassing the remote wire staight to power instead of the stereo
Oct 26, 2009 | Lanzar VW12D Car Subwoofer
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Car Audio & Video Logo
270 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
