Question about Hitachi 60EX01B 60" Rear Projection Television
Power supply what is the name and part number on the power supply which is marked on the pc board I904
  • 1,153 Answers
Is this I-904? if it is then it's the AC Clock. more info at
Posted on Dec 23, 2007
My LG front load washing machine, model WM3001HWA, has no power. What can I do?
Hello Kyle;
My name is Peter. I am a retired field service appliance technician.
You have 3 sensors in your unit, a thermal sensor, a position sensor and a door lock switch. These components will prevent you from running but, would not affect your power.
I assume you checked your circuit breaker to make sure you have power to your washing machine.
The slightest change in power supply, electrical power surge or power outage will knock out your boards. Magnetic fields and static electricity will knock out your boards. Are your appliances near a main power supply line in your home?
All appliance manufacturers recommend surge protectors if you have control boards in your appliance. Individual wall socket surge protectors cost about $20.00 at your local Home Depot or where ever. This is a good investment.
Ok, your have 3 control boards in your unit. One is the digital display board which has nothing to due with power supply.
The others are your main control board and your control panel board. Each of which can turn off power. The highest probability is the main control board. The part number for this board is EBR 44289820. The part cost $225.00 locally. You can probably get it for $180.00 if you search the internet. This is item A450 on the following link.
Remember static electricity can not out a board. Ground yourself by rubbing your hands over something that is steel. Either unplug your unit or turn the power off at your household fuse box. There are several clips holding the board in the casing. you must push outward to remove the board. Inspect the circuit back side for burn marks. If there are no burn marks you can still have a board component failure. DO NOT DISCONNECT ANY CONNECTOR PLUG IN. When you replace the board, you will replace one at a time.
Nov 23, 2014 | Washing Machines
Power fuse blows when you push power button
You haven't specified anything about the description [brand name, model number etc] of your TV here. Anyway, if the power fuse blows instantaniously as you switch ON the set, no doubt that, there is some dead short circuit in the power regulator board of your TV. Never put no more fuse or switch ON the set until this fault has been retified. Sometimes there will be some bulged of shorted capacitors in the power sully regulator bard of your tV. Check for it. I'm herewith attaches the picture of a power supply board of Tv, [not with your's;] for you to identify what a bulged capacitor will be. If there is such capacitors on your TV's power supply baord, just repalce it with same size and capacity. Its capacity will be marked on it. gopakumarg43_51.jpg
See the bulged capacitors, marked with red arrow. You can see a good one, on the top right part of the board with flat top. You haven't given anymore details of your TV here with your problem post. So I could only give you this much information and repair tips. If you want any more assistance from me, feel free to get me by FixYa. OK.
Sep 09, 2011 | Televison & Video
Power Supply Board needs replacement.If you need complete power supply board then click here and find the board according to the product name and complete model number and you will find all the details, If you need repair on component level then contact repair man to resolve the issue of power supply.
May 12, 2011 | Televison & Video
I have a Vizio (Model #:LP2626, Model Name:VMM26F20I) and I know the power supply board is the problem. However, I cannot find anything on the board with any sort of identifying part number. I've...
Well,Vizparts show the picture of the power supply board wright?Take ur tv aparts,take out the power supply board and compair the power supply board on the picture to ur real actual board.Try another website u can tries.
Oct 27, 2010 | Vizio VA26L 26 in. LCD HDTV
What problem would make the screen go black with vertical rows of hash mark down each side of screen?
ael 16504, If unit performs in same manner when connected to a "Known-Good" pc, then unit may need to have the internal power supply board (SMPS/inverter) checked out by you or qualified monitor technician. What is "date of manufacture" and model number? Have you seen any repair videos at YOUTUBE yet??? Was monitor working good 24 hours ago? Will your pc perform perfectly with a different monitor connected to it? When very "strange" stuff starts to occur with CCFL lcd monitors, the very first place this tech will look is at the SMPS/INVERTER power supply board. Do your research here in the fixya profiles of "budmrtn" "buddymc" 12fixlouie"(me) and at YOUTUBE for video clips of monitor power supply board repair (bad capacitors)
Report what you discover by doing another posting to this response by me. 12fixlouie
Aug 27, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
HP LC4776N power supply problem
Tries websites like, to research refurbish power supply board to buy.
Jul 21, 2010 | HP Lc4276n 42 in. LCD Television
How cane get power supply
Most LCD monitor manufacturer do not make their own Power supply/Inverter board, you need to get the name and number of the board and search on line. You can also have more than one version of the power supply for the same model.
These people sell boards:
What is wrong with the board any way?
Apr 04, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
CL-2 94V-0 E241819 is screened next to the embedded VIA 1ghz processor. the only other marking is V626EMP1G above memory slot. can you help me ID this motherboard?
what you have is a china no-name motherboard there are alot of these floating around. I've had a couple myself from shady builders there junk
if you can identify the board using cpuid try it
if you got some skill building pc's buy a new board, ram, processor, video card, and power supply if not a new basic desktop is cheep
Feb 10, 2010 | Jetway V266B Motherboard
Power supply for Emachine
WhoDoctorK9 is right. You'll need the model number of the pc to pull up any schematics of the board. This is, however, how you solve this problem. Just google your model number and try to find a schematic of the board.
If you can't find the schematic, the board should be marked with some sort of 'pwr' blah blah white lettering. It's hit & miss, but you can find the connection without visual aid by dimensions of the plugs and the obscure little identifiers on the board itself.
Good luck and may the force be with you. :P
Mar 27, 2009 | E-Machines eMachines Desktop PC
I need a diagram for the 5187-1098 power supply wire hook ups so I know I have installed it into my HP Pavillion a1240n desktop correctly
on the board in super tiny print is the lead names use a magnifying glass and look for f panel then you should see the connectors marked
Dec 17, 2008 | Computers & Internet
Hitachi 60EX01B 60" Rear Projection Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
