Magnavox converter box was working fine, got local channels clearly. Then after a storm I can only get one of these channels. The rest say 'no reception.' Any sugestions on restoring the other chanels? Thank you
  • 3 more comments
  • craig_overca Oct 06, 2009
    I am at work and will need to get it
  • craig_overca Oct 07, 2009
    Model # TB110MW9
    I believe the Magnavox converter box has a model number TB110MW9
  • craig_overca Oct 09, 2009
    I have a Magnavox converter box. It worked well, receiving all local channels until we had a storm. Now I can only receive one of the local channels, the others say no reception. The converter box model # is TB110MW9
    It was an electrical storm.....but one local channel was left untouched. Would it not have removed all channels? I will check the user's guide for a reset........would it be wise just to get a new converter?
    Guru:
  • 1,326 Answers
Try re programming the channels and making sure it didn't default to cable insead of Anteanna and then do an auto channel scan. If your using the convertor box you should be on channel 3/4 for it to broadcast ..
Posted on Oct 10, 2009
  • Televison & ... Master
  • 17,115 Answers
What kind of antenna do you have and what kind of storm was it?
If the storm had high wind, there is a chance that you need to re-orient your antenna and or clean the connections on it to remove moisture and be sure that they are tight. If the issue was an electrical storm there is a possibility that the converter has been damaged or picked up a stray electrical charge. Consult the owners manual on the converter about the reset feature.
Posted on Oct 09, 2009
Hi, is there any model number for the converter? Thanks
Posted on Oct 06, 2009
  • Anonymous Oct 06, 2009
    Thanks
I have 2 converter boxes which have been working
reprogram your converter box again by going to menu or setup channel search
Aug 30, 2009 | Televison & Video
Tv as of sun night says no signal....converter box was working
Re scan your channels. Analog is gone and alot of channels have moved. Just re-run the setup on your converter and it should be fine. The channel numbers may change, but the programming hasn't. Hope this helps
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
HELP !!! I HAVE 5 CONVERTER BOXES AND STILL "NO SIGNAL" APPEARS.
you could try waiting or .. make sure you tv is in "digital" not "analog"
May 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
Dish Network Channels Work but Local Television Channels Do Not
Do you have an antenna hooked up? You'll need one hooked to your converter box because the digital signal is so much more difficult to tune in to. This may help:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Apr 21, 2009 | Sony KDL46S3000 46 in. LCD HDTV
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
