Question about Balance CM2019 19" LCD Monitor
Does not power on, makes clicking sound, power light goes off and on. Sometimes it will come on and work perfectly but most times it just clicks and the screen remains blank. Swapped power converter box with another exact same model that works and it made no difference.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Srb111000, If unit won't work with substitute "black brick" power supply, then the problem will be inside of monitor! Most likely a failed INVERTER circuit board that supplies 800-1200 volts to light up the "cold-cathode-fluorescent-tubes" that provide "WHITE LIGHT" so you can see whats on your screen. The "clicking sound you hear is the internal safety circuit going "IN and OUT" of SHUTDOWN MODE trying to save itself from a NONRECOVERABLE CATASTROPHIC FAILURE and or FIRE. Leave it off! It's BROKE. A local tech type will need to evaluate it. Get back to me if you need some options as to what you think you need to do with it. Or read some of the other posts I have made concerning LCD monitor failures. lmistyrel @ aol .com or louie12fix on fixya
Posted on Oct 06, 2009
I have found that where the power connector plugs into the back of the monitor, it is loose & doesn't make proper contact. Wiggling it around creates that same kind of popping sound as it repeatedly powers on & off. My solution: push it in hard & to the left, creating a friction bias. Mine makes a connection & then I just don't bump it to leave it on; it stays on for months. I suppose you could add a layer of black electrical tape to 2 sides of the power connector, to make it slightly larger, so it fits in more snugly. Also, haven't tried to SLIGHTLY pinch 1 of the power pins in the monitor toward the other pin, again creating a better biased hold when the power plug (female) connector is plugged in. USE NO METAL TOOLS!
Posted on Apr 11, 2014
Epson v500 flashing green light
I have the exact same problem, sometimes it works and it starts warming up, but most of the time it just shows a green light and no response.
May 17, 2012 | Epson Perfection V500 Flatbed Scanner
No picture no sound click ok goes off
can you tell use the patter in which the light blinks??
it will help us to decode the problem easily
Jul 14, 2008 | Philips 50PF9956 50 in. HD-Ready Plasma...
My mazda tribute 2003 radio, interior lights, central locking system not working. I just put on ignation one day and heard a clicking sound and they all went off..what could be the issue? Fuses have been...
You still have a fuse or power down issue if clocks reset all the time recheck all fuses with a multi meter and make sure they are good sometimes looking at them is not good enough. If you don't know how to use an ohm meter Google it ok.
Nov 29, 2017 | 2002 Mazda Tribute
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
When my batteries run low on power the generator starts up. Most of the time the system works perfectly, but lately the inverter will click and keep clicking and the batteries will not charge, then the...
please check the voltage your generator is supplying to the to the inverter because a high voltage and frequency can make the relays in the inverter to make clicking sounds,and also do not allow your inverter batteries to run completely low before you charge it
Jan 06, 2010 | Xantrex Technology Trace Series Inverter /...
1995 ford f150 makes single loud click when trying to start
Does it make the loud click just once, or will it continue to click when you turn the key?
If it is just once, then there is still a bad connection someplace for the main power. If it continues to click every time you turn the key to "start", then it is probably the starter solenoid itself that is bad. There are two big terminals (bolts) on the solenoid, and if you connect a 12V test light or meter across them, you should see power there. If the light doesn't go out (or very dim) when you turn the ign. to 'start', then the solenoid is bad. If the light goes out and the starter doesn't turn, then there is something wrong with the starter. I suspect the solenoid also because it works better with a strong charge on the battery.
May 19, 2009 | 1989 Ford F 150
Digi002 interface not powering on
I just talked to Digidesign and apparently this is a problem with the DC power harness.  You can call them and they will send you a replacement harness at no cost, since it is a repair and a known issue.  Basically I was told that the problem was due to oxidation on the power contacts.  The oxidation prevents the unit from having constant power.  The clicking you hear are the relays going through the initial power sequence multiple times as they get power and then lose it again. In theory you could fix the problem temporarily with some contact cleaner.  They will be sending me a a package with the new (and improved) harness, instructions and contact cleaner.  I am assuming this will fix the problem once I get the chance to swap the harness myself.
Nov 22, 2008 | Digidesign Digi 002 Rack FireWire Pro...
Gas range (oven)won't lite (gas broiler works fine)
Sounds like an ignitor problem or possibly a dirty orifice. Model #'s are usually on the frame behind the bottom drawer.
Oct 04, 2007 | KitchenAid KGSI901PBS Gas Kitchen Range
Balance CM2019 19" LCD Monitor Logo
164 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
