Question about GE Microwave Ovens
Door won't open. push button doesn't work
  • GE Master
  • 9,047 Answers
It may be a broken door open lever or a worn door open button or both.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 06, 2009
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Door latch problem - doesn't always respond well
You will have to take the unit apart and see the reason. Could be a warn button or a bent part.
Dec 31, 2012 | GE Profile PEM31DMBB Black 1-cu-ft...
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door doesn't open when you push the open button>
Since no model number was posted, I have to give a general answer.
It's likely that one of the door opening parts (most likely the door open button or lever) is broken.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Sep 25, 2011 | Daewoo KOR-630A Microwave Oven
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
How do I repair the door latch for a Sharp Carousel R-530ESF microwave oven? The push button won't open the door. I had to use a putty knife to push the latch up and open the door.
The service manuals are at our site here and here.
You can order parts from the Sears Parts Direct Web site image-4235112-10659157 or Encompass here.
Jul 07, 2011 | Microwave Ovens
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door...
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
Jun 03, 2011 | Sharp R420L Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Oct 27, 2007 | DCS CMO-24-SS Convection/Microwave Oven
Microwave Ovens Logo
278 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
