Question about Kenmore Refrigerators
Can't get glass of water
Ice maker works fine but no water comes out for a glass of water.fridge is only a couple of years old, use to get a glass of water.
  • 2 more comments
  • avanasas Oct 06, 2009
    I hear a distinct click. should i still try switching the connections. you are talking to a novice, what is a solenoid. It is located near the copper tubing that goes into the fridge?
    Just checking to see if you got my last message. I believe I found the solenoid. One is blue and one is white.When I switch the white one the ice maker still works. I could not connect the blue one to the other side. It appears the female side of the connector will not let me connect no matter how hard I push.
  • avanasas Oct 07, 2009
    Cannot get glass of water from refrigerator, ice maker is working
    how do I verify that it is the solenoid before i go spending $80 on a electrical control board.
  • 3,741 Answers
Normally you have what is called a dual solenoid water valve. This is the part that your house water supply line is connected to on the back of the fridge. One line goes to the ice maker and the other to the water disp. This is a common fault part we replace almost daily. You can also have an issue with the dispenser itself. Some dispensers have electrical control boards that fail or micro switches depending on the model number that will make either the ice or water not work.
initially check if the water line is likely disconnected, or clogged at some point (maybe even at the filter).if the water line looks ok and is connected properly and not clogged than its definately the faulty electric control board thats causing this.---Get the board replaced if necessary as repaired boards wont last longer.the board costs approx 80 dollars.
thanks,keep updated and please rate the solution positively.
Posted on Oct 07, 2009
  • charlymonty Oct 07, 2009
    if the icemaker works with solenoid then it means that the solenoid is fine.just check water line for clogging and connections.if every thing looks fine.then its time for electric control board replacement.
  • 10,515 Answers
I somehow doubt that the reservoir is frozen. These are usually outside of the freezer area so that they don't.
I would like for you to try something for me. Go to the fridge and listen very carefully for any noise from the back of the unit when you push the water dispenser lever.
You should be able to hear a distinct click. That will be the dispensers solenoid opening up to allow water to flow through the system to the dispenser. If you do not hear the click this means that the solenoid has gone bad. They are not hard to change and you can do this yourself.
At the back of the unit where the water line connects to the unit there should be the two solenoids for the water and ice maker. Switch the electrical connections from one to the other and then try the dispenser again. If it works then this is defiantly your problem. disconnect one set of wires from one solenoid only. Try there dispenser again. If it does not work then that is the good solenoid you have disconnected. Change the other one.
The part should be available from your local appliance parts house.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 06, 2009
My ice machine stopped working on my fridge it's only 1 and 4 months old.any suggestions
If a year old there is no warranty for the ice maker or the dual water control valve. Feel around the ice slots to see if there is still sitting there? What is the model number of your fridge? If the ice tray slots are empty fill with tap water until near full and if the water freezes and the ice maker drops the ice into the ice container the problem will link to a water control valve problem. If there is ice in the slots and ice maker is on and does nothing then the problem is the ice maker and it will need to be replaced.
Nov 23, 2015 | Refrigerators
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Ice maker
Disconnect the plastic hose at the top of the refer (the one coming from the water valve) and set the end into a glass. After about two hours you should have water in the glass. If you have water in the glass then the spout that is inside the freezer is froze up and needs to be thawed out (use a blowdryer), If there is no water then it will be the valve or ice maker.
If it is froze up, adjust the cold controls back to the middle settings, you may have it to cold in your freezer.
Jan 18, 2008 | Frigidaire FRT17G4B Top Freezer...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
