Are you sure that you have the proper amount of fuel pressure? Low pressure will prevent a proper atomization of fuel at the injectors and ultimately poor performance. You should have over 45 pounds of pressure at the fuel rail at idle. If the fuel filter isn't clogged, it could very well be a weak fuel pump. You can verrify pressure with a mechanical fuel pressure guage at the rail.
Unfortunately it doesn't look like there are any special features, most of the entries revolve around reprogramming if you have to replace or renew the batteries.
There is, most likely a vacuum leak somewhere that is causing the high idle. Or the idle air control valve is malfunctioning. Some can be removed and cleaned, others may need to be replaced.
Seat base is not bolted.Grab under front of base with both hands near the ends and just snatch up quickly.Pull the seat base out from the car and the bolts for seat belts are visable.
If you have already purchased the replacement part; remove the door panel. Behind the mirror there will be three 10mm. Remove the bolts and replace the mirror.
REPLACE THE FUEL INJECTOR CANT REBUILT IT.IF YOU REMOVE FUEL INJECTORS FUEL RAIL YOU HAVE TO REPLACE GROMMETS AND O RINGS ON ALL THE FUEL INJECTORS IF NOT YOU WILL HAVE A INTAKE LEAK AT THE OLD FUEL INJECTORS SEALS.REPLACE THE FUEL INJECTOR YOU REBUILT THEY HAVE TO BE REPLACED.
